| | LinkBack | Thread Tools |
| | #1 (permalink) |
| 2nd Gear Member Join Date: Jan 2007 Location: Boston, MA.
| 1984 z50 making a loud noise in motor. HELP!!!
What's up PM people. My son's 1984 z50 starts and runs great but it sounds like a tractor. Something in the motor is making a clicking or thumping noise. It sounds like it could be a noisy valve train, or maybe the bike needs rings and a piston. Honestly, I have no idea. I'm not much of a mechanic. The bike also burns oil or smokes a lot when it's running. Besides the noise, the bike runs and start without a problem. I just would like to fix this noise before it does cause a problem. Any ideas would be great. Thanks.
| | #2 (permalink) |
| 1st Gear Member Join Date: Nov 2007
| Re: 1984 z50 making a loud noise in motor. HELP!!!
Do you have a missing pet hamster? I'm sure to catch hell for this, but I would just buy a new Chinese clone for a couple of hundred bucks, bolt it in and be done with it. The symptoms you have described are NOT good, and odds are severe damage has already been done. By the time you pay a "professional" to diagnose the problem, order OEM parts, and pay hourly for repairs you could probably buy a new Porsche instead, or put him through medical school at Harvard. Your results may vary. |
| | #3 (permalink) |
| 3rd Gear Member Join Date: Nov 2003 Location: CT . aaaaaah .... heh heh heh ..
My Mood: | Re: 1984 z50 making a loud noise in motor. HELP!!!
Bring it over to FastMc's house . He knows his stuff . |
| | #4 (permalink) |
| Classifieds Mod Join Date: Feb 2006 Location: Nor-Cal, CA
Disassemble the top end and check for damage there first. No use in tearing into the bottom end right away.
| | #5 (permalink) |
Recently I heard a bike with just such noise and it was the big end rod bearing . Once the top end is off , check that too . |
| | #6 (permalink) |
| 2nd Gear Member Join Date: Dec 2006 Location: Massachusetts, USA
Check the timing chain...could be way out of adjustment. Made one real quiet just doing this adjustment...see hondaheaven.com for pdf file service manuals.
| | #7 (permalink) |
| 2nd Gear Member Join Date: Nov 2007 Location: Birmingham, AL (Not a native.)
| Re: 1984 z50 making a loud noise in motor. HELP!!! |
| | #8 (permalink) |
| Re: 1984 z50 making a loud noise in motor. HELP!!! Try this for Z50R models: http://www.hondaheaven.org/files/manuals/z50r-shop.pdf and this for Z50a models: http://www.hondaheaven.org/files/manuals/honda50.pdf |
| | #9 (permalink) |
| Я выпиваю мочу Join Date: Feb 2007 Location: On the Moon
I ride with Grw and i am pretty sure its not a lower end noise. I believe the valves need adjusting, and the cam chain as well. It does make noise, but its not that bad. not like a knock or anything like that. I think it could also use rings. Its not the tranny. the transmission makes no noise at all. The noise increases with RPM no matter if you are moving or not. |
| | #10 (permalink) | |
| Re: 1984 z50 making a loud noise in motor. HELP!!! Quote:
| | #11 (permalink) | |
| "High Speed Record Guy" Join Date: Mar 2006 Location: Northern Virginia
| | #12 (permalink) |
Great Idea's fellows. I'll get Portland right on this. I'll let you know what he finds out. The bike still runs great and the last thing I'd do is put a china motor in it. I'd just part the sucker out and buy another bike. Thanks for all your help.
| | #13 (permalink) | |
![]() Do you know that Lifan is the world's largest producer of motorcycle engines and that they are ISO certified? You DO know what ISO certifications are, right? You are totally arrogant and ignorant to think that a 40 year old simple piece of **** 50cc engine like those that Honda produces cannot be mass quality produced in China. They are built to much higher standards than Honda made them even in 1986. Cessna is entirely building it's newest airplane in China. Boeing has Chinese made rudder assemblies in it's newest plane, the 777 Dreamliner. A piece of ****, no doubt. BMW has many major components for their engines built in Taiwan and very shortly, China. IT'S ALL JUNK 'cause the Chinese are a bunch of idiots that don't know **** from shinola. This is for his little kid's mini bike for christ's sake - not a freakin' Grand Prix racer. The engine is TOAST, VAPOR and HISTORY. | |
| | #14 (permalink) |
| Advertiser Join Date: Oct 2006 Location: Flint MI
You could toss an 88 kit and late model take off head for cheap...
__________________ If it has my name on it I did it;) FirepowerMinis.com Custom FPM parts and engines. Parts and service for all makes. Honda Trail Bikes parts and accessories. Pitster/Piranha/Thumpstar bikes, parts, engines and accessories. |
| | #15 (permalink) | |
| Sporting the Merkin Join Date: Mar 2004 Location: boston area
My Mood: | Re: 1984 z50 making a loud noise in motor. HELP!!! Quote:
| | #16 (permalink) |
I hope Cyclerider will chime in about the schooling. Cue "College is a place where....." |
| | #17 (permalink) | |
If it ain't broke, don't fix it. But if it is broke, for Christ's sake try to fix it! | |
| | #18 (permalink) |
| Re: 1984 z50 making a loud noise in motor. HELP!!! Very nicely said, or written arlindsay1992. I am going to give you an honorarily degree which, like some of these college degrees, are useless, but nice to have. Thanks for the input. Trying to fix it first is the smartest and cheapest route and heck, that's what this hobby is all about.
| | #19 (permalink) |
Grw, try putting sand in the oil fill.
| | #20 (permalink) |
That's a good idea. It acts like sandpaper and cleans up all the deposits and residues in the cases. Everything looks fresh afterwards.
| Bookmarks |
| Tags |
| 1984, loud, making, motor, noise, z50 |
| Thread Tools | |
