Old 09-09-2008, 04:08 AM   #1 (permalink)
2nd Gear Member
ducatilover's Avatar
My Mood: Cool
Question BrandX clutch conversion help. Cant shift past 1st gear
So I started working on my Z @ 10pm and @ 3am ran into a road block while installing my manual clutch conversion. Maybe you can help with the problem so I can get some sleep.
I just installed (well partially) a BrandX manual clutch conversion for my K4. I got the new shift shaft in but noticed the clutch only shifts from neutral to 1st gear. It shifts into 2nd every now and then but it usually will not go past second gear. Its seems like the thingie below does not spin all the way preventing the hook on the shaft to hook onto the next lobe. Has anyone ran into this problem? I tried putting the oem shaft back on and Im still getting the same problem. Any ideas on how to fix the issue? I searched the whole pm forum and found one other person having the same problem but no one reported a fix. Here is the person's description. Im having the same issue.
Quote:
Originally Posted by realgraverobber View Post
Installed my eBay (Brand X Minis) manual clutch kit, and I have the following issues/questions:
-When I upshift or downshify, the shifter sticks in the upswing or downswing, unless I touch it a tiny bit with my foot. It is not returning like it did as a stocker. Does this stop happening after the shifter is gets broken in more? The new shifter Brand X sent me with their kit looks a little craggy and not as nice and straight as the Factory Honda one. Any experience with this change?
ducatilover is offline   Reply With Quote
Old 09-09-2008, 10:12 AM   #2 (permalink)
"ZBBT"
BlackBeard's Avatar
My Mood: Aggressive
Re: BrandX clutch conversion help
you should be fine, sometimes you need the gears turning to continue shifting, my brand-x kit has been flawless in my crf. make sure when you install that shift shaft that the two spring ends go on either side of t he post on the engine case.
BlackBeard is offline   Reply With Quote
Old 09-09-2008, 11:16 AM   #3 (permalink)
"High Speed Record Guy"
arlindsay1992's Avatar
Did you test with the motor running? The tranny needs to be spinning to work unless you are in that magic spot when all the gears are aligned and can shift without spinning. If there is still a problem when running it sounds like one of the springs is loose. Maybe the detent arm spring or one of the two on the shift shaft.
arlindsay1992 is offline   Reply With Quote
Old 09-09-2008, 11:19 AM   #4 (permalink)
3rd Gear Member
boonacka's Avatar
My Mood: Sleepy
spin the wheel whil ein gear on the stand a bit and it should click in
boonacka is offline   Reply With Quote
Old 09-09-2008, 11:19 AM   #5 (permalink)
2nd Gear Member
My Mood: Cool
Quote:
Havent tested it yet. I was hesitant to put it back together fearing Ill have to take it apart again if the problem was still there. Ill have to give it a try. Has anyone used the stock shift shaft and just cut it down?
Old 09-09-2008, 04:01 PM   #6 (permalink)
Quote:
I have not done this myself but after comparison of the TB manual clutch shift shaft and an OEM one, I am positive that it would work fine. I would not hesitate using a cut OEM shaft if I didn't have a pre cut shaft. Be careful though, if it is too long it will hold the clutch cover off the case and the motor will leak oil it will also bind. If it is too short, you might have problems with the ratchet arm not lining up with the pins in the shift drum. You have a 1-2mm margin for error.
Old 09-09-2008, 04:22 PM   #7 (permalink)
3rd Gear Member
thorwarrior915's Avatar
My Mood: Bored
I am running a cut down honda auto shift shaft with my BXM clutch kit. arlindsay is right about cutting it down. I hadn't cut enough off the first time, and the shaft was bound up when i tightened the cover down. Compare the auto shaft to the manual shaft and you will see how much you need to take off.
I dont remember exactly what was wrong with the BXM shift shaft... but it just wasn't near the quality of a honda one. The return spring that goes on either side of that post on the case was thinner and weak, and the "pawl" that catches the pegs on the shift drum was not shaped as precise as the honda unit. I put the honda one in and haven't looked back.
thorwarrior915 is offline   Reply With Quote
Old 09-09-2008, 06:55 PM   #8 (permalink)
2nd Gear Member
My Mood: Cool
I do agree that the spring and the "pawl" are not as good as oem but I kind of expected that. I did reuse the stock return spring. I put some thread lock on the bolts and left them snug but Im still having the same issue. I tried rolling the bike while in gear and had no luck.
Old 09-16-2008, 08:40 PM   #9 (permalink)
2nd Gear Member
My Mood: Cool
Well I finished installing the kit today and am still having the problem shifting past 1st gear. I haven't started the motor yet but noticed the shifting problem was still there. Any more suggestions?
The install went ok. The quality is acceptable and there is a clearance issue with the clutch cable and the stock exhaust.
Old 09-17-2008, 04:55 AM   #10 (permalink)
It needs to be spinning to shift. START THE BIKE!!!
Old 09-17-2008, 06:00 AM   #11 (permalink)
2nd Gear Member
vegatron75's Avatar
I did the brand x clutch kit. I had big problems shifting the bike w/ the supplied shift shaft.
I eventually cut the the stock shaft down and used it instead.
vegatron75 is offline   Reply With Quote
Old 09-22-2008, 02:53 PM   #12 (permalink)
2nd Gear Member
My Mood: Cool
So I started the bike and crossed my fingers. No luck. I still cant shift past 1st gear. Clutch is adjusted and bike runs fine but I cant seems to shift past 1st. Any other suggestions?
Old 09-22-2008, 03:03 PM   #13 (permalink)
Did the shifting work before you did the clutch conversion?
Old 09-22-2008, 03:04 PM   #14 (permalink)
2nd Gear Member
My Mood: Cool
Shifted just fine on the auto clutch.
Old 09-22-2008, 03:04 PM   #15 (permalink)
Are you using the BXM shift shaft?
Old 09-22-2008, 03:06 PM   #16 (permalink)
2nd Gear Member
My Mood: Cool
Not sure what that is but Im using the one that came with the kit.
Old 09-22-2008, 03:08 PM   #17 (permalink)
BXM=Brand X Minis
I'd cut down the Honda shaft at this point.
Old 09-22-2008, 03:09 PM   #18 (permalink)
2nd Gear Member
My Mood: Cool
BXM=Brand X Minis
Thats what I was fearing I would have to do.
Old 09-22-2008, 03:22 PM   #19 (permalink)
3rd Gear Member
dirtbkr188's Avatar
Try swapping the Honda actuating arm and spring onto the BXM shift shaft, and see if that works for you.
dirtbkr188 is offline   Reply With Quote
Old 09-22-2008, 04:01 PM   #20 (permalink)
2nd Gear Member
My Mood: Cool
Quote:
Went into chat but you're not there. Im when you are available.
brandx, clutch, conversion
PlanetMinis
