| | LinkBack | Thread Tools |
| | #1 (permalink) |
| 2nd Gear Member Join Date: Jan 2005 Location: Hawthorn Wds, IL
| Carb problem
I have a 98 z50r and I bought a 03 honda motor already decked out and its running a Mikuni carb with the takegawa intake. The carb has a side pull choke and it hits the tank petcock. Now I cant put the tank back on with out it hitting the chock. I have tried swiveling the petcock but same issure occured. So should I buy a new intake from TB or should I buy this petcock from TB - http://www.hondatrailbikes.com/catal...roducts_id=395 but not exactly sure if the TB petcock will work. If any one has ran into this problem |
| | #2 (permalink) |
| 2nd Gear Member Join Date: Sep 2005 Location: circleville ohio
i did on my xr an i used a[i think,not shure what size] 17mm socket lol to space the tank up enough for it to clear,just the front was all i had to space the back was fine,good luck let us no if that will work
| | #3 (permalink) |
| The Golden Ticket Join Date: May 2006 Location: 5outh 5an 0iego
My Mood: |
get the petcock or get carb adjuster to swing it out of the way. http://tboltusa.com/store/product_in...roducts_id=130 |
| | #4 (permalink) |
| 2nd Gear Member Join Date: Nov 2006 Location: finksburg, md
quic free fix might be to spin the intake manifold 180 like the 110s have them not sure if it will clear have never tried it just thought of it.
| | #5 (permalink) |
| Sporting the Merkin Join Date: Mar 2004 Location: boston area
My Mood: |
I'm not sure if that petcock will work either but what sometimes works if you dont need too much more clearance is to take a dremel and oval the manifold mounting holes a little to pivot the manifold in the direction you need to go. Just make sure the manifold stays centered over the intake port. The problem with the 12 way adaptors is it raises the carb even more which can make the problem worse.
| | #6 (permalink) |
| 3rd Gear Member Join Date: Nov 2005 Location: Troy NY
post some pics of your 98.
| | #7 (permalink) |
Here is a pic, I have more but they wont post for some reason. I the tank has about 1 to 1.5 inches to move forward which totally makes it worse. I might be able to dremel the top of the choke knob off so it flat on top.
| | #8 (permalink) |
| 1st Gear Member Join Date: Jun 2006
i had the same problem, so i thought bugger it, got the old fitting removed and some brass bsp fittings fitted further forward
| | #9 (permalink) |
My Mood: |
Yeah thats a problem. Pivoting the manifold isnt gonna work. I'd be looking to get rid of the choke knob or get a different carb.
| | #10 (permalink) |
Damn, I bet the mikuni carb really rocks on this motor. Wonder if anyone would trade for a keihin carb?
| | #11 (permalink) | |
| Quote:
| | #12 (permalink) |
I'd use a dremel tool ...like you said. Grind the black plastic choke button way down so it's barely bigger than the metal piece it mounts too. As long as you can still grab it and pull it out, you'll be ok.
| | #13 (permalink) | |
| Quote:
| | #14 (permalink) |
I think I found my answer to fixing the tank hitting the carb problem. http://www.hondatrailbikes.com/catal...roducts_id=768 |
| Bookmarks |
| Tags |
| carb, problem |
| Thread Tools | |
