Old 02-28-2007, 05:36 PM   #1 (permalink)
3rd Gear Member
uno4cinco's Avatar
ct project, need help
will a gpx motor fit into a 1970 CT70? I have a $1000 budget for this build, I dont want to blow most of it on a motor.
uno4cinco is offline   Reply With Quote
Old 02-28-2007, 05:42 PM   #2 (permalink)
3rd Gear Member
Derekz93's Avatar
Just slob on th knob chase. I mean...uniCorn
Derekz93 is offline   Reply With Quote
Old 02-28-2007, 05:43 PM   #3 (permalink)
ZB50 Jedi
tmas's Avatar
Fiddy of the Month
I believe it will..... but the CT has a 6 volt system and the GPX is a 12 volt CDI system.
If you want lights to work you will have to install a lightning coil on the GPX motor.
You willl have to get a new wiring harness with it that has the CDI, voltage regulator ect. plugs.
tmas is online now   Reply With Quote
Old 02-28-2007, 05:47 PM   #4 (permalink)
3rd Gear Member
uno4cinco's Avatar
right, i knew that the older one was a 6volt. do you know where or who i can get a new wiring harness with a cdi, volt reg etc. from?
a gpx seems like a pretty good way to go, most chinese engines already have the stuff for electric too.
Old 02-28-2007, 05:59 PM   #5 (permalink)
ZB50 Jedi
tmas's Avatar
Fiddy of the Month
Quote:
Maybe find a harness on ebay? Make your own? Talk to a few vendors, maybe they have one? Do you want all the lights and turn signals and headlight to work?
Old 02-28-2007, 06:05 PM   #6 (permalink)
3rd Gear Member
uno4cinco's Avatar
yeah pretty much. i want that motor or a lifan, and i was looking at a friend of mines china motor and it has the 5 wires that come out of the case (ground and other wires for lights) so i figure i can get one of those and bolt it on?
are the CRF and chinese ignitions such as that on a GPX interchangable?
Old 02-28-2007, 06:14 PM   #7 (permalink)
2nd Gear Member
general_lee01's Avatar
post some pics of it
general_lee01 is offline   Reply With Quote
Old 02-28-2007, 06:23 PM   #8 (permalink)
3rd Gear Member
uno4cinco's Avatar
i will when i get home, its in need of some love for sure. i got the motor idea sorter out. im going to go with a Jailing and a high comp piston and cam in it.
My next dilemma is getting the lights to work with a 12 volt motor, who has done this? what problems am i going to run into and what parts am i going to need and who and where can i get them from? once again, convertine 6 volt stuff to 12 volt.
Old 02-28-2007, 06:48 PM   #9 (permalink)
Z
5th Gear Member
Z's Avatar
You are going to have to lower the footpegs so they don't hit the cases. Use spacers.
You'll need to convert all your bulbs to 12V, you'll have to run a 12V battery, coil and voltage regulator. Dratv has some information on the conversion.
there will be little snags here and there, but with some patience and a good set of wiring diagrams, you'll work through it.
Dan
Z is offline   Reply With Quote
Old 02-28-2007, 09:08 PM   #10 (permalink)
3rd Gear Member
uno4cinco's Avatar
thanks dan, does DR.atv also sell the parts?
Old 03-01-2007, 05:56 AM   #11 (permalink)
2nd Gear Member
makotosun's Avatar
My Mood: Amused
Everything you need.
http://cgi.ebay.com/ebaymotors/LIFAN...mZ150096747297
This includes all the lights (front, rear, blinkers), engine electrics, headlight shell, speedo, horn, keys, handlebar controls, etc, etc, etc. Good seller too. I got one of these for my upcoming conversion, as i already had the motor. Really hard to beat for the price.
makotosun is offline   Reply With Quote
Old 03-01-2007, 06:44 AM   #12 (permalink)
1st Gear Member
symp's Avatar
dr.atv sells everything you need for a conversion, and has diagrams and such like dan said
symp is offline   Reply With Quote
Old 03-01-2007, 08:37 AM   #13 (permalink)
ZB50 Jedi
tmas's Avatar
Fiddy of the Month
Thats a nice package for the price.
Old 03-01-2007, 04:12 PM   #14 (permalink)
3rd Gear Member
uno4cinco's Avatar
yeah, not sure if i am going to do a lifan kit anymore, i can get a good deal on a jailing so i may go that route, i image that kit would people fit on a lifan right?
Old 03-01-2007, 04:24 PM   #15 (permalink)
d0n
3rd Gear Member
d0n's Avatar
Very complete! I wonder why they include a gas cap? What's it fit? I'm curious what the speedo cable hooks to on the front wheel? I'm assuming it just attaches to a bike that already has the speedo gear on the hub? If the bike doesn't have a speedo gear then you're kinda screwed?
d0n is offline   Reply With Quote
Old 03-01-2007, 04:40 PM   #16 (permalink)
3rd Gear Member
dirtbkr188's Avatar
d0n,
Here is a pic of a CT70 front hub/brake panel, and the speedo cable threads into the hole just to the right of the front axle in the pic.
dirtbkr188 is offline   Reply With Quote
Old 03-03-2007, 11:37 AM   #17 (permalink)
d0n
3rd Gear Member
d0n's Avatar
cool I wonder what other hondas that hub would fit into? XR70 maybe?
Old 03-03-2007, 04:56 PM   #18 (permalink)
3rd Gear Member
dirtbkr188's Avatar
I can give it a test-fit on a CRF70 front wheel, d0n, and get back you with the results.
Old 03-03-2007, 05:29 PM   #19 (permalink)
d0n
3rd Gear Member
d0n's Avatar
Thanks! dont kill yourself. I'm curious though. It would be cool to have a speedo on my dirtbike. There must be more to it. Maybe a gear inside on the ct axle?
Old 03-04-2007, 03:17 PM   #20 (permalink)
3rd Gear Member
dirtbkr188's Avatar
d0n,
The CT70 hub isn't compatible with the CRF70 wheel I have here, it wouldn't work at all.
It appears as though the cable is driven by a worm gear inside the brake panel itself, and there is a ring-type gear with drive pins on it, the CT hub engages that, and turns the worm gear.
project
PlanetMinis
