Old 07-14-2008, 06:05 PM   #1 (permalink)
1st Gear Member
scott76's Avatar
CT70 fuel tank mounting / tubing routing
Can anyone post a pic or explain the gas tank mounting and tubing routing? I recently bought a couple of ct70's, and neither had a gas tank. Several are available on Ebay, but I'm confused bythe dual hoses. I assume one is a vent? I also am a little perplexed by the fuel on/off/reserve switch being mounted on the carb.
I will eventualy build a ct with a 12v motor with a lighting coil, but I'd like to get this one running as-is and sell it so I can build up the other one.
scott76 is offline   Reply With Quote
Old 07-14-2008, 06:31 PM   #2 (permalink)
"The Steg"
gstegman's Avatar
Re: CT70 fuel tank mounting / tubing routing
On is "on" while the other is reserve. There are two barbs on the petcock and they are marked "O" and "R". When you get the tank you will see which is which. The hoses route on top of the motor under the airbox. It is snug but that is where they go.
gstegman is offline   Reply With Quote
ct70, mounting, routing, tank, tubing
PlanetMinis
