| | LinkBack | Thread Tools |
| | #1 (permalink) |
| PM Newbie Join Date: Sep 2008 Location: rc
| ct70 help carb is driving me crazy
Im new to the site and man i am glad i found it. I have a lifan 125cc in my ct70 with a sheng wey carb, ive heard good and bad. I need to get this thing jetted the the stock jets are in it now and i have the needle all the way on the top clip i am under 100 feet elevation any help with what jets to run along with air/fuel screw adjustments? thanks |
| | #2 (permalink) |
| 3rd Gear Member Join Date: Oct 2008 Location: St.Joe MO
My Mood: | Re: ct70 help carb is driving me crazy
whats wrong with it?
| | #3 (permalink) |
Its just not jetted correctly. There was a stock 85 main jet in there and it would pop never could get a smooth idle. I have the needle clip on the top position which makes it a little better just looking for a good jet set up.
| | #4 (permalink) |
| 2nd Gear Member Join Date: May 2008 Location: Norman, OK
Use that Sheng Way piece of **** for a boat anchor and call it good. No, really buy a Mikuni or Keihin and never look back. Some of the Chinese crap out there right now is just that, don't waste your time.
| | #5 (permalink) |
where can i a keihin and what size jets should along with what size carb?
| | #6 (permalink) |
| 3rd Gear Member Join Date: May 2004 Location: New Jersey
What size ShengWay carb is it? The 20mm one? The 24mm one? Take a picture of it on the bike and post it up...
| | #7 (permalink) |
I can't upload from my phone I will from my computer later tonight here are some numbers written on the side Pckd k-15 K 70gy 6803 0930 0866 2-5 if this helps for now |
| | #8 (permalink) |
AHP has a 22mm real mikuni for 45 bucks, i got one.
| | #9 (permalink) |
here is a pic of the carb. |
| | #10 (permalink) |
That's the 20mm ShengWay carb, I use a #90 main jet, a #38 pilot jet, needle clip in the 3rd or 4th notch from the top, and start tuning with the air screw 1-1/2 to 1-3/4 turns OUT from seated. I make the air screw adjustments in 1/4 turn increments, sometimes with the air screw only 3/4 of a turn out from seated to have it run right. I've always found this carb to be easy to tune right out of the box.
| | #11 (permalink) |
thanks I am going to head down to mdk today and see if they have any jets. Ill let you know how it goes.
| | #12 (permalink) |
i went with a 95 main and a 38 pilot screw was at 1 turn out and needle on 4th clip from top runs like a champ. just cant figure out clutch adjustment now.
| Bookmarks |
| Tags |
| carb, crazy, ct70, driving |
| Thread Tools | |
