| | LinkBack | Thread Tools |
| | #1 (permalink) |
| 2nd Gear Member Join Date: Dec 2007 Location: Saginaw, MI
| Flywheel cleaning help
Flywheel from a '70 CT70. VERY rusty inside. How should I clean it up? Just some solvent or maybe lightly sand? Thanks in advance. |
| | #2 (permalink) |
| 2nd Gear Member Join Date: Feb 2007
| Re: Flywheel cleaning help
For rust removal I use stuff called "A must for rust" from my local home depot Just spray it on, brush in with a tooth brush, let it sit 5 minutes, spray it again, rub it in again, sit 5 minues.. Do that for about 30 minutes, and that'll usually remove all the rust I did that on my entire Fzr600 frame to paint it |
| | #3 (permalink) |
Thanks. BTW anyone know how to get out all the little metal shavings? I'm thinking a stronger magnet to draw them off.
| | #4 (permalink) |
| "High Speed Record Guy" Join Date: Mar 2006 Location: Northern Virginia
I just be patient and get the metal flakes with a paper towel. I don't know if it's possible but I would be worried the stronger magnet might screw with the ignition system. It might not, but I just use a paper towel, then I just take care to keep it clean.
| | #5 (permalink) |
Thanks. This is my first time rebuilding one of these bike engines. I have a manual, but it's short on tips and tricks.
| | #6 (permalink) |
| 1st Gear Member Join Date: Mar 2007 Location: Florida
I would sandblast it. You probably dont have one, but you could go to a local shop and ask them to do it. It would probably be just as cheap as the rust spray. But if you sandblast it it will look like brand new.
| Bookmarks |
| Tags |
| cleaning, flywheel |
| Thread Tools | |
