| | LinkBack | Thread Tools |
| | #1 (permalink) |
| 1st Gear Member Join Date: Jun 2006 Location: Athens, Alabama
| Freshly Polished Aluminum Parts
I spent most of the day today polishing the aluminum parts for my 50. I'm getting closer to getting it back together. Anyway, the alloy used on these bikes polishes great and looks almost like chrome. What do you guys think? /dayj1 |
| | #2 (permalink) |
| 2nd Gear Member Join Date: Jun 2006 Location: morris/wolcott CT
looks amazing howd you get it that shiny?
| | #3 (permalink) |
| 2nd Gear Member Join Date: Aug 2006 Location: Oklahoma
nice!!
| | #4 (permalink) |
| Advertiser |
Explain your polishing process if you dont mind. those look great.
| | #5 (permalink) | |
| Quote:
Well, it's not easy! My main hobby is restoring antique jukeboxes, so I have a lot of metal polishing equipment and supplies. Basically you start by cleaning all of the old paint/grease of the part. Then you have to sand out all the pits and scratches. You actually start with coarse 80 grit paper and work up to about 400 grit for aluminum. By the time you get to 400 grit, you can use a power buffer with various grades of compound to polish it to a mirror shine. If you're trying to polish a harder metal like stainless steel, you have to work up to about 1000 grit paper before you can use the buffer. You can see some buffing supplies at http://www.caswellplating.com to get an idea of the stuff you want to use. You COULD do it by hand, but you'd probably have to sand up to 1500-2000 grit before you could polish with a rag and some sort of metal polish. The parts in the picture took me about 8 hours to complete. Oh, and thanks for the compliment! /dayj1 | |
| | #6 (permalink) |
| "High Speed Record Guy" Join Date: Mar 2006 Location: Northern Virginia
The polishing I do with the dremel add ons don't look any shinier. The difference was so small I never even mentioned it. But that looks amazing. Good job.
| | #7 (permalink) |
One other thing to keep in mind is that not all aluminum alloys will polish to a high shine. While the Honda parts above polished nicely, I have found metals in the past that simply would not polish no matter how much work that I put into them. I think an engine case polished up would look sweet but I don't want to disassemble my motor completely and it would be very awkward trying to hold the bottom end of a 50 up to the buffer for a couple of hours /dayj1 |
| | #8 (permalink) |
| PM Newbie Join Date: Jan 2006
It is. I gave up before mine were anywhere near that shiny, but i wsh I had persisted. those bits look amazing
| | #9 (permalink) |
| 3rd Gear Member Join Date: Dec 2005 Location: Just south of hell, FL
My Mood: |
Thays just polished aluminum? Gorsh, it looks like chrome..... Real nice!
| | #10 (permalink) |
| 2nd Gear Member Join Date: May 2006 Location: murrieta ca
those look amazing, did you use tripoli compound for the buffing?
| | #11 (permalink) |
| 2nd Gear Member Join Date: Jul 2006
Im guessing its hard to keep that shiny though, correct? Cole |
| | #12 (permalink) | |
| Quote:
I started with black (emery compound), then brown (tripoli), then white (rouge), and finaly blue which is a rouge with no cutting action. But, yes, by far most of my time polishing is spent with the tripoli (brown) compound as it is the best to use on aluminum. /dayj1 | |
| | #13 (permalink) | |
| Quote:
/dayj1 | |
| | #14 (permalink) |
| 2nd Gear Member Join Date: Dec 2005 Location: JackSonville, Fl
Beautiful work! Can I send you some parts? |
| | #15 (permalink) |
damn, 8 hours, with professional polishing equipment, forget that 1 hour would be too long for me ahah |
| | #16 (permalink) |
| Sporting the Merkin Join Date: Mar 2004 Location: boston area
My Mood: |
Nicely done.
| | #17 (permalink) |
or you could spray them with clearcoat and not have to worry about tarnishing. I use semichrome polish on my old ducai |
| Bookmarks |
| Tags |
| aluminum, freshly, parts, polished |
| Thread Tools | |
