View Poll Results: Which wouldbe good to pull 190lbs but not to fast and on a budget
70cc 11 26.19%
85cc 13 30.95%
95cc 18 42.86%
Voters: 42. You may not vote on this poll
Old 09-10-2008, 08:40 PM   #1 (permalink)
2nd Gear Member
highho04's Avatar
Help building 70 motor
I am buildin an atc 70 motor and looking at the cheapest way to do it. What route should i take. I only use it to putt around town on and ride wheelies. It is actually pretty fine now i just ould like a bit more umph not a torque monster. And no im not throwing a lifan in it. I DONT CARE HOW CHEAP IT WOULD BE. So my thought is. . .
USING STOCK 70CC
1. Throwing a new set of rings in.
2. Using a thinner copper gasket
3. Throw in a new better cam
4. HD valve springs
5. HD cam chain
6. Anything else with this setup???
Using the dratv 85cc Kit
1.85CC_CYLINDER_KIT ATC70_ALL_YEARS CT70_TO_1981 ALL_SL_XL_TRX70'S
Using the 95cc dratv Kit
1.95CC_CYLINDER_KIT ATC70_ALL_YEARS CT70_TO_1981 ALL_SL_XL_TRX70'S (READ_DISCRIPTION)
highho04 is offline   Reply With Quote
Old 09-10-2008, 08:51 PM   #2 (permalink)
2nd Gear Member
highho04's Avatar
Re: Help building 70 motor
also want to eventually put this in too. . .
CDI_CONVERSION_KIT FOR_FOUR_SPEED TRANNY_MODELS (400073)
Old 09-10-2008, 10:10 PM   #3 (permalink)
2nd Gear Member
mikev's Avatar
May I ask why you are so adamantly against putting a Lifan in it?
mikev is offline   Reply With Quote
Old 09-10-2008, 10:21 PM   #4 (permalink)
3rd Gear Member
50rider340's Avatar
My Mood: Cool
i put a 88 kit on my trx70 and with a stock grind lifan cam and a e22 head and a 19mm carb and its absolutely a blast. I swaped out the crank and put a 12 volt one in it so i didnt have to deal with the shorter by 1mm rod length.
Isnt there a twelve volt braket conversion you can get to just bolt on a twelve volt stator and staor plate???
50rider340 is offline   Reply With Quote
Old 09-11-2008, 07:42 AM   #5 (permalink)
2nd Gear Member
highho04's Avatar
Quote:
I want to stay honda on this build
Old 09-11-2008, 07:45 AM   #6 (permalink)
2nd Gear Member
50minikid's Avatar
My Mood: Cool
and you need pull start lol
go with the 85 kit
50minikid is offline   Reply With Quote
Old 09-11-2008, 07:48 AM   #7 (permalink)
2nd Gear Member
highho04's Avatar
Quote:
go with the 85 kit
i already have pull start. im thinking the 85 as well do i need to bore the cases?
Old 09-11-2008, 07:54 AM   #8 (permalink)
2nd Gear Member
50minikid's Avatar
My Mood: Cool
I meant the lifan would have kick start.
Old 09-11-2008, 08:39 AM   #9 (permalink)
2nd Gear Member
fiddyonefiddy's Avatar
if you have the atc 70 motor
you already have the hot rod head.
you dont want to bore the cases out,so go with the 85cc kit.
fiddyonefiddy is offline   Reply With Quote
Old 09-11-2008, 08:48 AM   #10 (permalink)
3rd Gear Member
fatcaaat's Avatar
Well, you said the cheapest, right. The cheapest would be a different motor.
You put a 85cc kit on it, and the CDI conversion and you've broken $200. Not to mention that when yo put that 85 or 88 kit on there, you'll need to rejet your carb. To really get the benefit, you'll need a different carb and a different pipe...now we're talking more money.
And, if you put the dratv kit on there and a conversion, its no longer all honda...it is actually the same stuff you don't want...the chinese stuff.
If you want to be cheap, I suggest the following. Re-bore or re-ring it stock or +.25, .5 75 whatever, throw on an atc125m intake manifold and a mikuni VM20 carb. Add a performance cam and exhaust. It will go better than an 85 or 88 with your stock components. And unless you are running lights, just stick with the points ignition. No harm no foul.
fatcaaat is offline   Reply With Quote
Old 09-11-2008, 09:39 AM   #11 (permalink)
2nd Gear Member
My Mood: Dead
About the cheap method, will it work on a CT70H/SL70. That's ATC125 intake, VM20, cam and exhaust, how much more top speed?
stevec is offline   Reply With Quote
Old 09-13-2008, 10:17 AM   #12 (permalink)
3rd Gear Member
wayfastwhitey's Avatar
My Mood: In Love
tak 138 twinspark
wayfastwhitey is offline   Reply With Quote
Old 09-13-2008, 11:28 AM   #13 (permalink)
2nd Gear Member
highho04's Avatar
i said eventually a cdi. and i dont want a cheap china motor
building, motor
PlanetMinis
