Old 08-25-2007, 11:35 PM   #1 (permalink)
PM Newbie
profgrif's Avatar
Help with timing CT70 motor with 88 kit
Just installed a 71 CT70 motor in my 73 Z50 with an 88kit. Where should timing be set on this? Advanced or not? Having a weird fluctuation in timing when throttled. Timing light show slightly advanced but when throttled timing moves to the F and line on the case. Anyone have any ideas?
profgrif is offline   Reply With Quote
Old 08-26-2007, 07:54 AM   #2 (permalink)
"High Speed Record Guy"
arlindsay1992's Avatar
Re: Help with timing CT70 motor with 88 kit
Maybe you have the flywheel with the timing advance mechanism. And the only way I ever set points is with this amazing tool.
arlindsay1992 is offline   Reply With Quote
Old 08-26-2007, 09:23 AM   #3 (permalink)
PM Newbie
profgrif's Avatar
I use a timing light. What I am saying is where do you set the timing with this motor and 88 kit?
Should it be F lined up with the notch or advanced a little or?
Just didn't know if it is different now since it's not stock anymore.
Old 08-26-2007, 09:25 AM   #4 (permalink)
Stock is the F mark. I have no timing advance on my Z50R, so I set it advanced past the F about 3-4 degrees.
Old 08-26-2007, 09:30 AM   #5 (permalink)
PM Newbie
profgrif's Avatar
you think this motor has a timing advance? My other CT70 stock doesn't do this.
Why does it retard a little when throttled?
It starts about 3 degrees advanced at idle and when throttled moves to the F mark.
Old 08-26-2007, 01:28 PM   #6 (permalink)
3rd Gear Member
dirtbkr188's Avatar
Did you ride the bike with the timing set where it is yet? If not, take it for a test ride, and see how it runs. If it doesn't seem to be running right for you, readjust the points a little, and test ride it again. If it is better, keep tweaking it in that direction; if worse, go the other way on the points adjustment.
dirtbkr188 is offline   Reply With Quote
ct70, kit, motor, timing
PlanetMinis
