Old 02-20-2007, 07:46 PM   #1 (permalink)
d0n
3rd Gear Member
d0n's Avatar
Identify these parts
I got these number plate mounts from a PM member but they don't come close to fitting. The longer one on the left is about 1/2" to an inch to short and the little one on the right isn't even close. Am I crazy or are these really from an 80's z50r?
d0n is offline   Reply With Quote
Old 02-20-2007, 08:42 PM   #2 (permalink)
3rd Gear Member
dirtbkr188's Avatar
I'll measure the one I have here and post up the findings for you, d0n...
Is it possible that the longer one is for the exhaust side, and the shorter one is for the ignition side?
dirtbkr188 is offline   Reply With Quote
Old 02-20-2007, 08:52 PM   #3 (permalink)
ZB50 Jedi
tmas's Avatar
Fiddy of the Month
These are the ones off my 82. not perfectly straight.
tmas is offline   Reply With Quote
Old 02-21-2007, 04:57 AM   #4 (permalink)
"High Speed Record Guy"
arlindsay1992's Avatar
d0n, the one on the left is for the left side on a 1980-1987 Z50R. The one on the right is the for the left side on a 1979 Z50R. The 1979 Z50R had a different mounting bracket on the left side and none on the right. I'll post pictures of both of my frames in a little bit.
arlindsay1992 is offline   Reply With Quote
Old 02-21-2007, 05:46 AM   #5 (permalink)
Here you go.
1979 Frame and brackets:
1984 Z50R Frame and brackets:
Old 02-21-2007, 05:47 AM   #6 (permalink)
d0n
3rd Gear Member
d0n's Avatar
tmas, good pics. How long is the one in the bottom pic... eye to eye?
That's right Q! Thanks.
Old 02-21-2007, 10:42 AM   #7 (permalink)
2nd Gear Member
Fullthrottle's Avatar
euuhhh those parts are to hold the plate number on each side...
Fullthrottle is offline   Reply With Quote
Old 02-21-2007, 11:10 AM   #8 (permalink)
d0n
3rd Gear Member
d0n's Avatar
Eureka! Thanks!
Old 02-21-2007, 02:48 PM   #9 (permalink)
3rd Gear Member
dirtbkr188's Avatar
d0n,
The bracket I have here is from the right side of an '86, it measures 8-1/16" eye-to-eye by 3-15/16" bolthole-to-bolthole.
Old 02-21-2007, 03:06 PM   #10 (permalink)
d0n
3rd Gear Member
d0n's Avatar
thanks. the longer part of the long one I have is 7 1/4" bolt to bolt.
Old 02-21-2007, 03:08 PM   #11 (permalink)
ZB50 Jedi
tmas's Avatar
Fiddy of the Month
Quote:
d0n... 7 3/4 inches going length wise. Let me know if you need any other measurements.
identify, parts
PlanetMinis
