| | LinkBack | Thread Tools |
| | #1 (permalink) |
| PM Newbie Join Date: Aug 2005 Location: TC,Michigan
| Lifan 110cc replacement engine w/71 ct70
Will this Lifan engine drop right in to the Ct70? http://cgi.ebay.com/ebaymotors/Lifan...spagenameZWDVW Will all the electrical stuff hook right up? Also, where's the best place to get motard tires? Thanks |
| | #2 (permalink) |
| 1st Gear Member Join Date: Jan 2005 Location: Yucaipa -909-
yea it should drop right in. you will have to do some wiring though i think
| | #3 (permalink) |
| 2nd Gear Member Join Date: May 2006 Location: murrieta ca
you can get street tires at www.scooterpartsdirect.com also dr.atv sells some tires for 19 bucks each, he doesn't list the brand but they're cheap. |
| | #4 (permalink) |
| 3rd Gear Member Join Date: May 2004 Location: New Jersey
You'll also have to upgrade the wiring and lights to 12V, as the electrical system on the CT70 is only a 6V system.
| | #5 (permalink) | |
| 3rd Gear Member Join Date: Oct 2004 Location: Maple Ridge BC Canada
| Quote:
| | #6 (permalink) |
| 1st Gear Member Join Date: Mar 2005 Location: SW Washington St.
i bought a 50cc from this guy...had great customer service...i couldn't understand the wiring, when i called he led me thru it completely...his website is www.hooperimports.com |
| | #7 (permalink) | |
| 2nd Gear Member Join Date: Dec 2005 Location: JackSonville, Fl
| Get a 125cc for a little more $$ Quote:
http://cgi.ebay.com/ebaymotors/ZONGS...spagenameZWDVW | |
| | #8 (permalink) | |
| The Golden Ticket Join Date: May 2006 Location: 5outh 5an 0iego
My Mood: | Quote:
| | #9 (permalink) | |
| 3rd Gear Member Join Date: Jun 2005 Location: Monticello, Mn
My Mood: | Quote:
| | #10 (permalink) | |
| Old School Z50s Join Date: Jun 2005 Location: NEW JERSEY PINELANDS
My Mood: | Quote:
| | #11 (permalink) |
I'm liking that Zongshen 125cc better than the 110cc lifan. How hard is it to swap it over to 12V? I'm mechanically challenged, but I would like to be able to do it myself.
| | #12 (permalink) | |
| Bullet proof so far Quote:
It has a 23/27 valves, 54x54 bore/stroke, bigger 20mm counter shaft so you need the appropriate counter sprockets, and a ring-style stator, like the ZB, not a half lighting coil and half ignition setup. Very robust so far. I am running a dual headlights (65watts total) and it keep them lit up. And the Flywheel is actually 4oz lighter than the one in my 110 zongshen. I haven't had any tranny issues either. I did dino based oil for the break-in and now running full synthetic. I ride street, so I do not know what would happen after grabbing 10-20 feet of air like the motard/pitbike races. But high rev shifting up and down, no problems. Matt (the seller) is a great guy to deal with too. | |
| | #13 (permalink) | |
My Mood: | Quote:
| | #14 (permalink) | |
| Quote:
| Bookmarks |
| Tags |
| 110cc, ct70, engine, lifan, replacement, w or 71 |
| Thread Tools | |
