| | LinkBack | Thread Tools |
| | #1 (permalink) |
| 3rd Gear Member Join Date: Oct 2008 Location: St.Joe MO
My Mood: | lifan 125 eating ignition systems [help]
so this time it quite while i was riding it i noticed so of the rubber sleeve on the spark plug wire was melted no biggie i have one of my old one from the last time my ignition fried tried it no spark. so i tried my old coil, no go must have been fried also tried my old cdi no go must have been fried? don't think it should be the primary coils. guess i try and see if i barely have enough money for a new spark plug coil and cdi box? any ideas. ANY comments appreciated.
| | #2 (permalink) |
| Sporting the Merkin Join Date: Mar 2004 Location: boston area
My Mood: | Re: lifan 125 eating ignition systems [help]
First thing to try is disconnect the kill switch. Check all grounds and wiring connections. Do you have any known good parts you can swap out or just questionable ones ?
| | #3 (permalink) |
not really i will check the ground and disconnect that kill switch later...today hope fully. thank you for commenting.
| | #4 (permalink) |
| 3rd Gear Member Join Date: Sep 2004 Location: Arlington, VA
If you keep going through ignition systems, you better check your entire wiring harness and scheme. I've logged 1000's of miles and have only every had one ignition system fail and that was because of something I did. Check your grounds and for cracks/splits in any of the wiring.
| | #5 (permalink) |
the first time we didn't have grounds hooked up, yeah figured that one out quick green to green and 1 green to frame. just getting up going to tinker on it some more today, something tells me i have to wait till pay day for parts cause i'm gonna need em'.
| | #6 (permalink) |
my old man says the spark plug wire probably grounded out on the exauhst pipe when it got melted and said it wasn't a direct ground? does that make since possible just bad luck?
| Bookmarks |
| Tags |
| eating, ignition, lifan, systems, [help] |
| Thread Tools | |
