Old 01-11-2009, 02:37 PM   #1 (permalink)
PM Newbie
need a new head and engine rebuild Q
I bought a 83 z50 a while ago and I am now going to rebuild the motor.
I noticed the exaust port is broken so I need a new head.
I want to keep this fairly stock - maybe an 70/88cc kit.
What I am wondering is will a stock xr/crf head work with this year?
I can find more used xr/crf heads than z50 heads.
I also have a little slop in the rod - normaly this is a Split cases put in new bearings - does it matter with these little bikes?
Thanks cant wait to get this bike going finally!
dirt1016 is offline   Reply With Quote
Old 01-11-2009, 02:44 PM   #2 (permalink)
2nd Gear Member
LoudFastUgly's Avatar
Re: need a new head and engine rebuild Q
Every honda horizontal engine chips at the exhaust port. Give us a pic. If you can feel movement in the rod it should be addressed. Perhaps a crate motor might be cheaper and easier.
LoudFastUgly is offline   Reply With Quote
Old 01-11-2009, 02:50 PM   #3 (permalink)
3rd Gear Member
dirtbkr188's Avatar
You will have to use the XR/CRF piston to go with the XR/CRF head, the Z piston is slightly domed and will contact the XR/CRF head/valves.
Is the slop in the rod a slight bit of lateral sideplay, or is it and up-and-down slop? Generally, the lateral sideplay is normal, but there is no room for vertical play at all.
If need be, pick up a parts engine, they are around. A lot cheaper than having a crank rebuild.
dirtbkr188 is offline   Reply With Quote
Old 01-12-2009, 05:27 AM   #4 (permalink)
PM Newbie
Thanks
the slop in the rod is a little side to side. Nothing up and down.
The damage to the exausts port is on the under side of the head and it a good size chip out of it. I will take a pic. It needs to valves as well.
I need a new pipe and silencer. I was going to get a used stock to keep it quiet and the $$ low unless there is a better option that is cheap.
engine, head, rebuild
PlanetMinis
