Old 11-19-2009, 03:52 PM   #1 (permalink)
PM Newbie
My Mood: Drunk
Oh Boy, I need help again
as a bunch of you I have been having trouble getting the correct sprocket for my 72 ct70HK1 and the lifan 125cc, well after running in my garage for about a month without a sprocket on it I finally got it on and got one pass down the driveway, before my kick start doesnt turn over my engine, it will turn it over when there is a low amount of compression, but then it just slips, anyone else have a problem with the lifan doing this???? and if so how do I fix it. Thank you Justin
jkg2003 is offline   Reply With Quote
Old 11-19-2009, 06:20 PM   #2 (permalink)
2nd Gear Member
schofell84's Avatar
Re: Oh Boy, I need help again
sounds like a clutch adjustment? maybe someone else can chime in.
schofell84 is offline   Reply With Quote
Old 11-19-2009, 06:36 PM   #3 (permalink)
3rd Gear Member
doopsx3's Avatar
My Mood: Amused
me thinks so too
doopsx3 is offline   Reply With Quote
Old 11-19-2009, 07:16 PM   #4 (permalink)
Advertiser
firepower354's Avatar
My Mood: Amused
I'll turd the motion.
__________________
If it has my name on it I did it;)
FirepowerMinis.com
810-237-9537 M-F 9-6
Custom FPM parts and engines.
Parts and service for all makes.
Honda Trail Bikes parts and accessories.
Piranha/Medina/Thumpstar bikes, parts, engines and accessories.
Old 11-19-2009, 07:38 PM   #5 (permalink)
PM Newbie
My Mood: Drunk
so how do i do this
Old 11-19-2009, 07:43 PM   #6 (permalink)
PM Newbie
My Mood: Drunk
i just reread my first post and let me explain again... my kick start used to kick just fine and just two days ago, I kicked on it and it seemed to slip right through the cycle, but there was no grinding or anything like that, that made me think I had broken teeth, and if I turn it over by hand, then it will turn over with the kick start. please help
Old 11-19-2009, 07:44 PM   #7 (permalink)
3rd Gear Member
doopsx3's Avatar
My Mood: Amused
did it slip thru very easily or was there a drag
Old 11-19-2009, 07:46 PM   #8 (permalink)
PM Newbie
My Mood: Drunk
fairly easily
Old 11-19-2009, 07:50 PM   #9 (permalink)
3rd Gear Member
doopsx3's Avatar
My Mood: Amused
well if ya can push the kicker down with one or two fingers, the starter is not engaging...if it requires more effort than that it is possible that the clutch plates are slipping
Old 11-19-2009, 07:52 PM   #10 (permalink)
PM Newbie
My Mood: Drunk
ohk if the clutch plates are slipping how do I fix it and no I can push it will my hand
Old 11-19-2009, 07:55 PM   #11 (permalink)
3rd Gear Member
doopsx3's Avatar
My Mood: Amused
well you can first adjust it to see if that helps and if not you will need to replace the plates or springs
Old 11-19-2009, 08:08 PM   #12 (permalink)
PM Newbie
My Mood: Drunk
how do I adjust it????
Old 11-19-2009, 08:13 PM   #13 (permalink)
3rd Gear Member
doopsx3's Avatar
My Mood: Amused
Loosen the clutch adjuster lock nut and turn adjuster bolt 1 full turn counter-clockwise. Turn the adjuster bolt clockwise until resistance is felt. Turn 1/8th turn back counter clockwise and tighten lock nut.
Old 11-20-2009, 04:55 AM   #14 (permalink)
1st Gear Member
sanigene's Avatar
Quote:
Sorry, about to highjack. One of my bikes has the deal you described as "the starter is not engaging"...is there a fix for that?
tia,
sani
sanigene is offline   Reply With Quote
Old 11-20-2009, 05:54 AM   #15 (permalink)
PM Newbie
My Mood: Drunk
that worked perfectly thank you so much.
Old 11-20-2009, 06:00 AM   #16 (permalink)
3rd Gear Member
doopsx3's Avatar
My Mood: Amused
Quote:
no prob
Old 11-20-2009, 06:01 AM   #17 (permalink)
3rd Gear Member
doopsx3's Avatar
My Mood: Amused
Quote:
tia,
sani
Honda or China engine
Old 11-20-2009, 09:08 AM   #18 (permalink)
1st Gear Member
sanigene's Avatar
Honda fiddy
sani
Old 11-20-2009, 09:42 AM   #19 (permalink)
3rd Gear Member
doopsx3's Avatar
My Mood: Amused
Honda fiddy
sani
when did this start happening..need mo info
Old 11-20-2009, 12:40 PM   #20 (permalink)
1st Gear Member
sanigene's Avatar
I bought the bike second/third/forth hand , I dunno - used anyway. Motor is out of a K2, now in a lifan frame. The starter has been 'that way' since I got it. Basically you kick and it has little or no resistance and makes a whiiirrrrp type sound...similar sound as if you rubbed your fingernail down a backpack or thin carpet...and it obviously makes no attempt to crank the motor. I probably do three false kicks before I get a good one that cranks the motor. I always thought it had something to do with teeth not being properly aligned internally and I just accepted it....
sani
boy
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
PlanetMinis
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
