Old 11-15-2008, 12:31 PM   #1 (permalink)
PM Newbie
125ss's Avatar
TB 117 kit in a 6 volt engine?
Can I use a TB 117 kit in a Honda 6 volt engine (1976), if I run a 12 volt stator and flywheel?
Honda Trail Bikes
How many hp does the TB 117 deliver?
Do you think itīs a good kit?
125ss is offline   Reply With Quote
Old 11-21-2008, 02:34 PM   #2 (permalink)
PM Newbie
Giffin774's Avatar
Re: TB 117 kit in a 6 volt engine?
I have a tb 117 and i am vary happy with it. I sent the fly wheel out and had is shaved down. That helped big time. Also if you use the 6 volt case the stator bracket and so do not fit 100%. Yes on the 117, you will need to do some work to make the 12 volt fit.
Giffin774 is offline   Reply With Quote
Old 11-21-2008, 04:49 PM   #3 (permalink)
3rd Gear Member
fatcaaat's Avatar
Quote:
There are some threads on here discussion the abilty to change over a 6v system to a 12v system. Do a seach and you should find what you are lookin for. IN a nutshell, the answer is yes, but you have to mod the cases to make the new electronics fit.
fatcaaat is online now   Reply With Quote
Old 11-24-2008, 09:24 PM   #4 (permalink)
PM Newbie
what kind of hp does the 117 kit have and is it easier to get your flywheel shaved down or just get a lighter one?
codyisfastona50 is offline   Reply With Quote
Old 12-07-2008, 08:06 PM   #5 (permalink)
PM Newbie
Giffin774's Avatar
I am not 100% but lets say low teens. Ya.. you can buy a after market fly wheel kit from e-bay but, that my be to light. It really depends on on your riding. I use my 117 for just around the house with 15/37 gearing, works good for me. I think i had spent just under a 100 with shipping to have my fly wheel changed. Also if you run a VM 26mm carb, i think it is too much use or try a 24mm if you change the your fly wheel.
engine?, volt
PlanetMinis
