Old 06-11-2006, 09:21 AM   #1 (permalink)
d0n
3rd Gear Member
d0n's Avatar
z50a to z50r will some parts fit?
I'd like to put a set of adjustable bars from a z50a on my z50r's. If I had the foldable bars I could haul these minis in my station wagon instead of hauling the trailer. Otherwise, I'd have to remove the z50r bars for transporting.
Can this swap be done? Do the z50a bars bolt onto the z50r triple tree or will I need the z50a triple tree and bars to mount on my z50r?
thanks for any advice.
d0n is offline   Reply With Quote
Old 06-11-2006, 09:30 AM   #2 (permalink)
3rd Gear Member
lowbike1's Avatar
ya, as long as you have the whole setup, you will need the top plate as well cause the holes are spaced differently
lowbike1 is offline   Reply With Quote
Old 06-11-2006, 09:38 AM   #3 (permalink)
d0n
3rd Gear Member
d0n's Avatar
cool thanks!
Old 06-11-2006, 09:53 AM   #4 (permalink)
2nd Gear Member
birddogg's Avatar
My Mood: Twisted
Can't you just loosen your bars in your clamps and fold them back to fit? Just tighted them back up so you can still handle the bike. That's how I haul my XR in my jeep. The old 50 bar setup would be a lot of hassle unless you found everything complete for a good price. Even then, you have that funky banana bike bar bend. Might be cool for cruising the street, but not a good off-road bend.
birddogg is offline   Reply With Quote
Old 06-11-2006, 10:03 AM   #5 (permalink)
3rd Gear Member
Outlaw Powersports's Avatar
Quote:
Stock bars on a Z50R do not fold. They do not have adjustable bar clamps. Bars bolt right to the upper tree.
Outlaw Powersports is offline   Reply With Quote
Old 06-11-2006, 10:10 AM   #6 (permalink)
d0n
3rd Gear Member
d0n's Avatar
Quote:
yup
Old 06-11-2006, 11:22 AM   #7 (permalink)
3rd Gear Member
wreck's Avatar
My Mood: Buzzed
I have a set of fold down bars if you want to try them out.You might have to redrill your top plate but no big deal.
http://www.planetminis.com/classifie...-out-of-my.htm
wreck is offline   Reply With Quote
Old 06-11-2006, 12:55 PM   #8 (permalink)
2nd Gear Member
birddogg's Avatar
My Mood: Twisted
Didn't realize he was still running stock bars. That's usually the first thing to go in the trash.
Old 06-11-2006, 06:13 PM   #9 (permalink)
3rd Gear Member
dirtbkr188's Avatar
Actually, the 1979 Z50R had conventional bar mounts, which are still available from Honda. The OEM Part numbers are below:
dirtbkr188 is offline   Reply With Quote
Old 06-11-2006, 08:24 PM   #10 (permalink)
3rd Gear Member
Quote:
Was not aware of that. And my son has a '79 with adjustable mounts. I thought they were aftermarket. Thanks for the info.
Old 06-11-2006, 08:25 PM   #11 (permalink)
d0n
3rd Gear Member
d0n's Avatar
cool!
Old 06-11-2006, 08:48 PM   #12 (permalink)
2nd Gear Member
birddogg's Avatar
My Mood: Twisted
A lot of my friends use the clamps from TRX steering stems or ATC uppers. Dirtbkr188 knows his Z's.
Old 06-14-2006, 09:48 AM   #13 (permalink)
3rd Gear Member
wreck's Avatar
My Mood: Buzzed
http://www.planetminis.com/classifie...or-mx-bars.htm
fit, parts, z50a, z50r
PlanetMinis
