Go Back   Planet Minis > Forum > General Talk > KLX110, DRZ110, TTR90
Old 10-23-2009, 12:34 PM   #1 (permalink)
2nd Gear Member
My Mood: Cheerful
motor build help
i wanna build a 146 with a stroker crank. the motor is a stock 03 klx 110 motor now.. what all do i need to make sure its not gonna break? output shaft etc?
sxrscer189 is offline   Reply With Quote
Old 10-23-2009, 12:57 PM   #2 (permalink)
2nd Gear Member
My Mood: Cheerful
Re: motor build help
bump
Old 10-23-2009, 01:06 PM   #3 (permalink)
PM Newbie
slayerklx's Avatar
My Mood: Asleep
output shaft should do the trick, maybe billet 2nd gear... hth
slayerklx is offline   Reply With Quote
Old 10-23-2009, 01:09 PM   #4 (permalink)
3rd Gear Member
Paxracing's Avatar
My Mood: Breezy
I would add a 4 speed drum to it.
Paxracing is offline   Reply With Quote
Old 10-23-2009, 01:28 PM   #5 (permalink)
2nd Gear Member
My Mood: Cheerful
yeah im gonna do a 4th gear... so just an output shaft?
Old 10-23-2009, 03:11 PM   #6 (permalink)
Advertiser
firepower354's Avatar
My Mood: Amused
You'll want a primary gear, too, and a good clutch. We've got some package deals available, and deep discounts on kit & labor combos. Bore the cases while it's apart, so you can go BIG if you want.My 177 skirted combo is just a little more than a 155.
__________________
If it has my name on it I did it;)
FirepowerMinis.com
Custom FPM parts and engines.
Parts and service for all makes.
Honda Trail Bikes parts and accessories.
Pitster/Piranha/Thumpstar bikes, parts, engines and accessories.
build, motor
PlanetMinis
