Go Back   Planet Minis > Forum > General Talk > KLX110, DRZ110, TTR90
Old 11-01-2009, 10:40 AM   #1 (permalink)
2nd Gear Member
SunValleyMX's Avatar
My Mood: Mellow
Need some help timing my engine w/ inner rotor
So ive been building my engine up a little bit with a 143 kit and need some help timing it. I have an inner rotor kit (pretty sure its chinese made) and I was wondering if anyone knows where the timing marks are on it. Ive never done it with any aftermarket ignition system. Heres a pic of it
SunValleyMX is offline   Reply With Quote
Old 11-01-2009, 10:42 AM   #2 (permalink)
2nd Gear Member
My Mood: Mellow
Re: Need some help timing my engine w/ inner rotor
Or do I just install the head when its at TDC and then line up the mark on the cam gear?
Old 11-01-2009, 12:31 PM   #3 (permalink)
3rd Gear Member
JohnnyB's Avatar
My Mood: Inspired
I'd check it like this ....
- Remove the crank shaft nut and see where the key way is pointed with the inner rotor ..
- Then where it would be pointed if the stk flywheel were installed ..
If I remember correctly ..., on a honda irk ... The flywheel key way usually points twords the middle of the head .. But .., it may be different with the kawi one is positioned ???
JohnnyB is online now   Reply With Quote
Old 11-01-2009, 02:40 PM   #4 (permalink)
2nd Gear Member
My Mood: Mellow
Thats a great idea! Luckily I have another 110 in the garage with a stock ignition so I can just pop the cover off, line up the marks, and see where the key way is. Sweet! Thank you
Old 11-01-2009, 08:26 PM   #5 (permalink)
3rd Gear Member
JohnnyB's Avatar
My Mood: Inspired
Thumbs up
Quote:
No problem .., glad to help out ...
engine, rotor, timing, w or
PlanetMinis
