| | LinkBack | Thread Tools |
| | #1 (permalink) |
| 2nd Gear Member Join Date: Nov 2008 Location: Ma
| smoke coming out of engine breather hose
theres alot of smoke coming out of my breather hose could this be too much oil i put a quart and a 1/8
| | #2 (permalink) |
| 2nd Gear Member Join Date: Jul 2006 Location: Monee, IL.
| Re: smoke coming out of engine breather hose
I would like to know also since mine is doing that. Mine is also burning oil also or at least its coming out the exhaust. Most likely mine is rings or valve seals though.
| | #3 (permalink) | |
| 1st Gear Member Join Date: Oct 2006 Location: Michigan
| Re: smoke coming out of engine breather hose Quote:
Could be rings, cylinder bore, or seals----most of the time if its the seals it will smoke once you start the motor up then go away, but if its smoking all the time--rings or cylinder bore or both. Need to check cylinder with a bore gauge. How much time on rings/cylinder? | |
| | #4 (permalink) |
| 3rd Gear Member Join Date: Jul 2008 Location: Lynnwood, WA
My Mood: | Re: smoke coming out of engine breather hose
too much oil, or you have burned your crank bearings up.
| | #5 (permalink) |
| Re: smoke coming out of engine breather hose |
| | #6 (permalink) |
oh. didnt get it till now. it could be that your cylender is warped/ out of round too.
| | #7 (permalink) |
Bought the motor used and was supposed to have only a couple of hours which I say was not. I will have to pull it apart and see. So what would smoke coming out of the crankcase vent tube mean.? |
| | #8 (permalink) |
Okay you just answered my question after I posted. LOL Thanks guys Will have to take it apart and most likely will get a new cylinder kit then. |
| | #9 (permalink) | |
Smoke or an oil mist coming out of breather? If its smoke you got a bad blow by problem---rings or cylinder. | |
| | #10 (permalink) |
i put a quart and a 1/4
| | #11 (permalink) |
just put a quart of oil and the brether blew some oil out and smokes
| | #12 (permalink) |
checked the crank its fie and the cylinder isnt ovaled i have oil coming spitting out too just changed the oil put 1 quart in have no idea help please
| | #13 (permalink) |
i got a 26 mm vm carb 143 tb kit stock head stroker crank 4th gear shift drum dont no what could be making oil spit out this left side breather
| | #14 (permalink) |
did u check piston and rings?
| | #15 (permalink) |
yes sir they were good it blows oil and smokeand bikes running hot like i have the trai bikes manual clutch and it gets so hot after rinding it i cant touch the clutch cover or ill burn my hand that hot
| | #16 (permalink) |
it didnt go it till i gotthat 26 mm carb
| | #17 (permalink) |
| 3rd Gear Member Join Date: Mar 2004 Location: ca
What oil are you running.
| | #18 (permalink) |
spectro 10-40 clutch saver but ive used motul also and same thing happend
| | #19 (permalink) |
i mean the crank it brand new the 4th gear shift drum is new the clutch is new the piston and rings new and cylinder im using the stock head with trail bikes 143 kit and i just put the 26mm vm carb on 3 days ago and since then this has been happening
| Bookmarks |
| Tags |
| breather, coming, engine, hose, smoke |
| Thread Tools | |
