Go Back   Planet Minis > Forum > General Talk > KLX110, DRZ110, TTR90
Old 11-29-2006, 06:57 PM   #1 (permalink)
1st Gear Member
06TwoBros110's Avatar
Location: Im in CT... ive got my own track complete with 7ft. mini fmx kicker....
TB134 tick noise help
ive got an 06 110 with trail bikes 134 bbk... 134 not 143.... stock carb and stock head.. it runs mint but it makes a little tick noise thats is costing me the sale of it.. it doesnt sound like an alumnium tick it sounds like a steel tick.. ive heard that the steel cylinder makes this noise and that its perfectly fine but i just want to make sure.. maybe its a valve out of ajustment tick.. idk.. the thing is tho also i just installed a tb 88 kit on a crf70 with stock head and carb and it also makes the same tick noise but the valves are set to the right ajustment on that.. im just trying to figure out what makes this tick noise.. the steel cylinder? something with the valves and cam? please help me out so i can sell this thing..
06TwoBros110 is offline   Reply With Quote
Old 11-29-2006, 08:11 PM   #2 (permalink)
2nd Gear Member
surfex's Avatar
My Mood: Yeehaw
It is the cam. I am told they make this noise and it is normal with those kits.
surfex is offline   Reply With Quote
Old 11-29-2006, 08:27 PM   #3 (permalink)
3rd Gear Member
Mx356's Avatar
Ya my 134 and 143 both did that. Scary at first but never had any problems
Mx356 is offline   Reply With Quote
Old 11-29-2006, 09:18 PM   #4 (permalink)
3rd Gear Member
MXracer115's Avatar
my tb 134 made a ticking noise too, i was told that all tb kits do that, its nothing to worry about, mine ran good
MXracer115 is offline   Reply With Quote
Old 11-30-2006, 01:34 AM   #5 (permalink)
2nd Gear Member
galster12mX's Avatar
could be valves ticking, too tight.
galster12mX is offline   Reply With Quote
Old 11-30-2006, 04:37 AM   #6 (permalink)
1st Gear Member
galster im just wondering if it is prolly normal cause both the tb kits do it on the 110 and on the 70.. just i am sure that the valves are set right on the 70 cause i just did them and i did the 110 valves a while ago so they are prolly dialed in.. the 70's intake valve was at about .009" of an inch at first and it made a horrible tick that i knew was a valve.. i set it to .003" and it was mint afterwards just the normal little TB ticks.. soo i just need to convince this kid that iits all normal.. thanks all
Old 11-30-2006, 07:50 AM   #7 (permalink)
1st Gear Member
trixr4kids250's Avatar
Mine got real bad on my 134 i adjust the valves to as perfect as i could get and they quited down quite a bit
trixr4kids250 is offline   Reply With Quote
Old 11-30-2006, 11:41 AM   #8 (permalink)
1st Gear Member
ite thanks
Old 11-30-2006, 11:41 AM   #9 (permalink)
1st Gear Member
what should they be set to with this kit? like .003" or .004" right?
Old 11-30-2006, 02:14 PM   #10 (permalink)
1st Gear Member
RMZ290's Avatar
Cam chain have to correct tension?
RMZ290 is offline   Reply With Quote
Old 11-30-2006, 07:40 PM   #11 (permalink)
1st Gear Member
the valves are set and the cam chain is tensioned right.. i email TB and am waiting on a reply.. im convienced that its normal seeing as how i rode it like that for 8 months but i just need some hard evidence to show the buyer.. thanks all
Old 12-01-2006, 04:11 AM   #12 (permalink)
1st Gear Member
MIne are set to a tight .003
Old 12-01-2006, 01:24 PM   #13 (permalink)
1st Gear Member
crf106's Avatar
that is normal for them to tick. run a kitaco silent cam chain and it quietens it up. not sure how they do work but it does. good luck with the sale
crf106 is offline   Reply With Quote
Old 12-01-2006, 10:50 PM   #14 (permalink)
PM Newbie
One10's Avatar
I have the same setup, TB 134 w/ cam, stock head and carb. I've adjusted the valves so many times but it doesn't seem to quiet down any so I'm guessing it's normal. Pushing a year of hard riding and not one problem.
One10 is offline   Reply With Quote
noise, tb134, tick
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
PlanetMinis
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
