| | LinkBack | Thread Tools |
| | #1 (permalink) |
| 1st Gear Member Join Date: Jan 2004 Location: Your moms house
| Clutch cover side oil leak
Got a gpx 160 and on the clutch cover side there is a small oil leak. Take the cover off and at the top right side there is a bolt with washer and that is where the leak is from. What is this???? I would have got pics earlier today but forgot....
| | #2 (permalink) |
| Re: Clutch cover side oil leak |
| | #3 (permalink) |
| PM Newbie Join Date: Mar 2009 Location: Vancouver
Not to sure but i think thats where the nuetral switch is on my lifan 150 so that could be what that is.
| | #4 (permalink) |
| 2nd Gear Member Join Date: Jan 2009 Location: Bay Area, california
My Mood: | Re: Clutch cover side oil leak
well first off that the ignition side, behind that black plug there will be a bolt with a washer, your right, that's for the shift drum stub.
| | #5 (permalink) |
| | #6 (permalink) |
| | #7 (permalink) |
My Mood: | Re: Clutch cover side oil leak if you go to tighten that bolt, make sure the little spacer in there is slightly bigger so when you go to tourq it down itll still be free and easy movement. Because that shifts slightly when your shifting your bike.
| | #8 (permalink) |
| Re: Clutch cover side oil leak Yeah i noticed that it turned when i looked at it, now i know why.
| | #9 (permalink) |
| Advertiser Join Date: Oct 2006 Location: Flint MI
You'd have to have it overfilled, recently laid the bike on that side, or have a pinched breather, to get a leak there.
__________________ If it has my name on it I did it;) FirepowerMinis.com 810-237-9537 M-F 9-6 Custom FPM parts and engines. Parts and service for all makes. Honda Trail Bikes parts and accessories. Piranha/Medina/Thumpstar bikes, parts, engines and accessories. |
| Bookmarks |
| Tags |
| clutch, cover, leak, oil, side |
| Thread Tools | |
