| | LinkBack | Thread Tools |
| | #1 (permalink) |
| 1st Gear Member Join Date: May 2009 Location: Toronto
| lifan 140 engine oil?
What oil do I use for my lifan 140? It doesent say on the engine and I accidentally threw out the last oil containers Thanks |
| | #2 (permalink) |
| Advertiser Join Date: Oct 2006 Location: Flint MI
My Mood: | Re: lifan 140 engine oil?
Some. Non-synthetic.
__________________ If it has my name on it I did it;) FirepowerMinis.com Custom FPM parts and engines. Parts and service for all makes. Honda Trail Bikes parts and accessories. Pitster/Piranha/Thumpstar bikes, parts, engines and accessories. |
| | #3 (permalink) |
is that all? just non synthetic?
| | #4 (permalink) |
| 3rd Gear Member Join Date: Aug 2008 Location: San Diego
My Mood: | Re: lifan 140 engine oil? |
| | #5 (permalink) |
whats the uhm...viscosity?
| | #6 (permalink) |
| 3rd Gear Member Join Date: Mar 2004 Location: CT
concept just like with any other mechanical engine. When climate is HoT use thicker CoLd use thinner. If you run a search on the site there is prolly 123498723498723 posts.
| | #7 (permalink) |
| 2nd Gear Member Join Date: Mar 2009 Location: Mesa, AZ
10-40 would probably work all year long for you in toronto. get anything cheap without friction modifiers in it
| | #8 (permalink) |
alright, thanks for the help
| | #9 (permalink) |
| 2nd Gear Member Join Date: Dec 2008 Location: Pennsylvania
I just use pennzoil 10-30 and change it out every like 3 rides
| | #10 (permalink) |
| 1st Gear Member Join Date: May 2006 Location: TX
Our little bikes are no diff than our big ones---I personally run either Rotella 15w40, or Rotella synthetic 5w40, depending on my budget. True ester synthetic is good stuff, and the more of a revver you are, the more you need it. In a sportbike, you can literally feel the reduced engine vibration when revving hard, and the engine noise is quieter...
| Bookmarks |
| Tags |
| 140, engine, lifan, oil |
| Thread Tools | |
