Go Back   Planet Minis > Forum > General Talk > Chinese/Import Minis - General Discussion
Old 02-24-2007, 09:13 PM   #1 (permalink)
Classifieds Mod
Post ***Post Your Current Engine Specs***
I thought this would be cool for us import guys and/or gals.
Post what engine your running and the specs (i.e. 125,131,140,107,110,etc.)
I guess I will start.
-Gpx stock
-Xtreme engine stock
cmktech is offline   Reply With Quote
Old 02-24-2007, 09:21 PM   #2 (permalink)
2nd Gear Member
ghostryder's Avatar
ahp stage 4 140, which consist of a GPX with (I believe) a TB 140 bbk, a high compression piston, G2 cam, port and polished head, lightened oil sling, and lightened flywheel. It has a 26mm OKO carb that I still need to dial in, Ive just been to busy with other projects and making a living. Even with out the carb set right, it rips.
ghostryder is offline   Reply With Quote
Old 02-24-2007, 09:23 PM   #3 (permalink)
Classifieds Mod
ghostryder you are one lucky person! pm sent!
Old 02-24-2007, 09:30 PM   #4 (permalink)
3rd Gear Member
RcWannabe's Avatar
05 SDG 107
AHP High Comp Piston
Crower G2
Ported and Polished
Head Shaved .040
Kitaco Inner rotor
Lightened Sling
Mikuni vm26 with tak manifold
Fuel= vp u2
Dyno'ed 10hp with 28ft lbs LOL not sure on actual numbers but I like how it runs it has more of a two stroke powerband than a bb GPX.
RcWannabe is offline   Reply With Quote
Old 02-24-2007, 09:31 PM   #5 (permalink)
2nd Gear Member
orracle's Avatar
My Mood: Bored
GPX 125 stock. soon to have chp hc piston, tb cam, lightened oil sling, lightened flywheel, and mild porting.
orracle is offline   Reply With Quote
Old 02-24-2007, 09:31 PM   #6 (permalink)
2nd Gear Member
wheelyking400's Avatar
tb 88 with ahp race head and race cam. The head is ported and polished. i also have a tb manual clutch with billet housing and kitaco IRK. im using a stock tb 20mm carb and running a fast 50s pipe and this thing moves pretty good for an 88
wheelyking400 is offline   Reply With Quote
Old 02-24-2007, 09:37 PM   #7 (permalink)
3rd Gear Member
melloyello's Avatar
A PIECED TOGETHER 117
Lifan cases
1 down 3 up tranny
Ported E22 head
G2 cam
54mm piston kit(dratv)
TB 51mm stroker crank
TB manual clutch
PE24 carb/Uni dual stage
It's in my xr70.
95cc For sale
Lifan cases
4 down (rotary) tranny
E22 head
Lifan auto clutch
melloyello is offline   Reply With Quote
Old 02-24-2007, 09:51 PM   #8 (permalink)
110cc home brew Honda
CRF70 bottom end
Tak 3spd + Clutch
TB stock head cam
Dr ATV Ultra head
Dr ATV 54mm crank
Cylinder from Minichopperfan bored to 51mm (Thanks again!)
Dr ATV 51mm piston
Mikuni TM24 carb
Kitaco long intake
Powroll header + Supertrapp can
Lifan stator + Cat5 lightened flywheel + TB CDI
SDG Coil
edit: I can't read... does using an import ignition count as an import motor? :P This motor ran ported E22 heads for quite awhile while I was searching for, and found 7hp at 72cc with a stock cam.
Lifan Monster 120
TB race head cam
TB cylinder bored to 57mm
Tak 57mm KLX110 Superhead piston
SDG OEM Mikuni 22mm carb
Kitaco IRK + Cat5 lightened oil sling
Kitaco Supercoil
Pitster Pro X2 header and can
Kurlon is offline   Reply With Quote
Old 02-24-2007, 09:56 PM   #9 (permalink)
3rd Gear Member
melloyello's Avatar
Quote:
CRF70 bottom end
Tak 3spd + Clutch
TB stock head cam
Dr ATV Ultra head
Dr ATV 54mm crank
Dr ATV 51mm piston
Mikuni TM24 carb
Kitaco long intake
SDG Coil
Just curious, what made you go w/ a 54mm crank and a 51mm piston? Just to keep it 110cc? Probably a little torquey too huh?
And to your edit: It's amazing what a port on an E22 can do isn't it?
Old 02-24-2007, 10:01 PM   #10 (permalink)
2nd Gear Member
ghostryder's Avatar
maybe it worth mentioning, I run a 14/12 wheel set up.
Old 02-24-2007, 10:05 PM   #11 (permalink)
Class limit of 110cc, and I wasn't happy with my 72cc motor's complete lack of bottom end when I was finally done with it, so I went undersquare. Result is a motor with plenty of bottom end, a good finish on top, but a PITA to get cylinders for.
And yeah, it was pretty much all porting that took my 72cc machine from 4.5hp to 7hp, I'm a believer in a good port job! : )
Old 02-24-2007, 10:09 PM   #12 (permalink)
3rd Gear Member
HACKMUNCH's Avatar
1 bad mofo (ask anyone that has tried to ride it) 146cc jialing, 57mm akunar pro piston, 28/24 lifan head, r 20 takegawa cam, crf 450 kibblewhite springs, 28mm d slide , kitaco inner rotor, no oil sling and on and on. just way to much HP for a 10" tire.
HACKMUNCH is offline   Reply With Quote
Old 02-24-2007, 10:11 PM   #13 (permalink)
2nd Gear Member
Quote:
thats why you should trade motors with me! lol i need a motor like that for my heavy 70... that would be a blassssst!
Old 02-24-2007, 11:15 PM   #14 (permalink)
3rd Gear Member
My Mood: Amazed
146 jialing. SGR head 28/24 valves. Lightened slinger, lightened flywheel, akunar pro piston, trailbikes cdi. Not sure if I should go with a 26 or a 28mm carb.
twitchy is offline   Reply With Quote
Old 02-24-2007, 11:37 PM   #15 (permalink)
TRT
3rd Gear Member
TRT's Avatar
My Mood: Amused
119cc..(In bike)
+R S12 cam ported by RKfinch23
52mm DRP crank
54mm Kitaco piston
Takegawa complete Trans kit
Kitaco IRK
FMF big bore pipe
24mm Keihin
set of broken cases...It sucks just broke them tonite
143cc 50 based( on bench half way done)
56mm crank/57mm piston
+R head S20 or S35 cam
complete takegawa Trans setup/honda cases
26 or 28 carb..Not sure which one I will use
140cc SGR Jailing(on bench finished except carb...)
big valve SGR Racing head...reworked valves...
Akunar piston
Aluminum oil slinger
Kitaco IRK
24mm Keihin or maybe 26mm Mikuni...Not sure yet
Working on a RKMotorsports Jailing (waiting on head)
RKMotorsports Big valve Lifan head 30/24 new seats...
146 or 163...crank depending
Akunar piston
aluminum oil slinger
Kitaco IRK
28mm Dslide carb/Kitaco intake
That should be all of them for my rides..
10/10 Motard (bike done)
12/12 Motard(still in the makings)
10/12 MX (bike done but just broke cased)
12/14 MX (bike half way built waiting on engine parts)
This does not include my sons CRF 50.....
TRT is offline   Reply With Quote
Old 02-24-2007, 11:46 PM   #16 (permalink)
1st Gear Member
breeding10's Avatar
137cc xtreme
55mm wiseco piston
cooper tranny
crower g18 cam
staggs irk
mikuni 26mm carb
FMF factory 4.1
breeding10 is offline   Reply With Quote
Old 02-25-2007, 12:03 AM   #17 (permalink)
2nd Gear Member
RM898's Avatar
Stock 125cc extreme.
Soon to have:
131cc BBK
Inner Rotor kit
Crower cam
H-bomb pipe
RM898 is offline   Reply With Quote
Old 02-25-2007, 08:14 AM   #18 (permalink)
PM Newbie
Lifan 138cc.
Z40 Race cam.
"Standard" Race valve springs.
26mm round-slide Keihin carb.
Takegawa polished manifold
Soon going to put kitaco copy inner rotor, and kitaco power coil
Ali1212 is offline   Reply With Quote
Old 02-25-2007, 08:40 AM   #19 (permalink)
2nd Gear Member
GPX Trailbikes 140 Lifan, 27-23 Valve ported head ,Trailbikes manifold ported and matched, 26 mm Mikuni carb Trailbikes Cam, Lightened Oil sling & flywheel
H Bomb pipe and this is way to much motor for me but good riders love it
micro75 is offline   Reply With Quote
Old 02-25-2007, 09:11 AM   #20 (permalink)
3rd Gear Member
ryan2282's Avatar
Big Valve zonger - 135cc
27/23
Crower g2
Head work done by dragndave
56mm dr atv piston
Yosh pipe
Mikuni tm24
Going down to miami in a bit for al ittle tlc from dave at kendall motorsports. should really rip even more.
ryan2282 is offline   Reply With Quote
current, engine, post, specs
PlanetMinis
