Go Back   Planet Minis > Forum > General Talk > Honda CRF70
Old 02-27-2009, 03:37 PM   #1 (permalink)
1st Gear Member
b-dub675's Avatar
Engine Noise????
I bought my girlfriend a 99 xr70, didn't run but cleaned the carb and got it running. There is a ticking or knocking noise coming from the left side of the motor. I didn't let it run long, something definitely isn't right. Checked oil, and valves, timing, the cam chain tensioner spring is longer than it should be, so i bought new cam chain, spring and the plastic cap for the tensioner. Getting ready to put back together just wondering if there is anything else i should check while i have it all apart.
b-dub675 is offline   Reply With Quote
Old 02-27-2009, 04:02 PM   #2 (permalink)
Advertiser
firepower354's Avatar
My Mood: Amused
Re: Engine Noise????
How much longer was the worn cam chain? I've seen some real streched ones.
__________________
If it has my name on it I did it;)
FirepowerMinis.com
810-237-9537 M-F 9-6
Custom FPM parts and engines.
Parts and service for all makes.
Honda Trail Bikes parts and accessories.
Piranha/Medina/Thumpstar bikes, parts, engines and accessories.
Old 02-27-2009, 04:10 PM   #3 (permalink)
1st Gear Member
b-dub675's Avatar
it really doesnt look that much shorter than the old one, like almost identical. i had the stator plate off and was kicking it over and the tensioner moves like crazy. i dont know if thats normal. and my girlfriend almost took the chain off by hand with the tensioner in
Old 02-27-2009, 06:23 PM   #4 (permalink)
Old Fart
Grafixxs's Avatar
My Mood: Amused
dub, you ready to put some zokes on that bike yet? I got a set of KTM 65 forks coming off a bike real soon.
Cam chain tensioner is bad, replace it.
Grafixxs is offline   Reply With Quote
Old 02-28-2009, 07:12 PM   #5 (permalink)
1st Gear Member
b-dub675's Avatar
got crf80 forks on the way.
Old 02-28-2009, 07:21 PM   #6 (permalink)
PM Newbie
My Mood: Grumpy
Looks like you are going to need a longer swingarm now
kitchen157 is offline   Reply With Quote
engine, noise
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
PlanetMinis
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
