Go Back   Planet Minis > Forum > Classifieds > Bikes and Parts Wanted - All Makes
Old 03-25-2009, 09:11 AM   #1 (permalink)
3rd Gear Member
fatcaaat's Avatar
Need Rear Front brake master, disc brake setup, exhaust, stator
I'm looking for a few items to complete something here.
1. Rear brake setup. I need the actuator, line, and caliper here. I would prefer a caliper that doesn't require the cheap ass brackets that don't ever work right...I will make my own bracket for it. As long as the caliper floats within itself and not off the bracket, I'll consider it.
2. Exhaust. I really want a pitster exhaust to be honest.
3. I need a china stator that is working. I don't care if it has a lighting coil or not. No inner rotor. I don't need the flywheel...just the stator.
4. Need a brake lever/master cylinder and line for a front brake. Just about anything will work here.
fatcaaat is offline   Reply With Quote
Old 04-11-2009, 12:13 AM   #2 (permalink)
3rd Gear Member
50$Pit's Avatar
Fiddy of the Year
Re: Need Rear Front brake master, disc brake setup, exhaust, stator
Rear disc brake setup: http://www.planetminis.com/f11/bbr-p...ml#post1255917
50$Pit is offline   Reply With Quote
Old 04-11-2009, 12:18 AM   #3 (permalink)
3rd Gear Member
doopsx3's Avatar
My Mood: Sick
I will check 2morrow 'caaat..I know I have the stator and I think I have the front brake...sorry only got 1 rear brake set and I am using it on my ST90 'Tard project...no Pitster stuff other than forks
doopsx3 is offline   Reply With Quote
brake, disc, exhaust, front, master, rear, setup, stator
PlanetMinis
