Go Back   Planet Minis > Forum > General Talk > NSR50, NSF100F, MB5, NS1 and RCV Mini
Old 07-23-2009, 04:18 PM   #1 (permalink)
PM Newbie
Ysr50 problem any help?
Having a problem with my ysr bogging. Think it is not getting enough fuel. It happens when taking off, shifting through first, second, third gears, wide open is great but when I shift into 4th or5th it bogs and wants to shut off. The bike has a 60 big bore piston kit k&n filter and jet kit, Dg pipe. The tank has been coated properly and nothing is showing up in the tank filter or the clear inline filter. Its almost like it is sucking the bowl dry in the carb. The fuel is premix with yamalube 2r oil. I am pulling my hair out trying to figure this out. It has to be fuel, everything electrical and the plug is new.Any Helpfull hints or ideas would be great. It idles great and runs perfect untill you are at WOT for 10 or 15 seconds running through the gears.
coop50 is offline   Reply With Quote
Old 07-23-2009, 06:27 PM   #2 (permalink)
PM Newbie
Re: Ysr50 problem any help?
Have you always had this problem? Is it a new bike to you? Have you cleaned the carb?
electricladyland is offline   Reply With Quote
Old 07-23-2009, 06:37 PM   #3 (permalink)
2nd Gear Member
ducatilover's Avatar
My Mood: Cool
did you check your float level? What size carb?
ducatilover is offline   Reply With Quote
Old 07-23-2009, 09:16 PM   #4 (permalink)
1st Gear Member
Manimal's Avatar
Quote:
what size carb are you using?.....I ask cause you mention a K&N filter
It may be that your carb needs to be tuned (correct jetting and or needle clip needs adjusted).
Call Team Calamari and get their opinion
Manimal is offline   Reply With Quote
problem, ysr50
PlanetMinis
