Go Back   Planet Minis > Forum > Classifieds > Import/Chinese Parts for Sale
Old 10-14-2008, 06:16 PM   #1 (permalink)
3rd Gear Member
fatcaaat's Avatar
63mm Crank, Head, and Motor Part
I'm looking to part or sell this motor as a whole.
It is a Lifan 120 base with the following stuff: Makes 155cc and with a 57mm kit makes 161cc
Ported Lifan BVH with 27/23 valves - $70
Z40 Cam - $30
Complete CLutch Basket, HD Springs - $30
Complete Kickstarter - $20
Complete Transmission - $75
56mm piston and cylinder - $70
GPX Crank with 6mm stroker Pin making 63mm - $200
SDG Shift Fix Kit - $20
Anything Else that normally comes in an engine. Whatever.
China Stator and FLywheel with lighting coil $30
This motor has about 100 total street miles on it. I built this from all new parts and then I sold this with my CL70 and the guy had it about a week and he couldn't shift it. Turns out what really happened is that he didn't know how to start it and busted the right side case. I took it back on goodwill because I thought that perhaps it was my fault. It wasn't. I have it broken down on the coffee table and it is clean, and otherwise perfect. The motor is basically new, but needs a right hand case and the little gear that meshes into the clutch basket. We're talking about 60 bucks.
So, if I can sell off ALL the pieces, I'd part it. Surely there are people that need these. If I can't part it, I'll fix it and run it as it was an awesome build.
If someone wants it complete when fixed, I can do that too...just let me know.
63mm Crank, Head, and Motor Part-img_2889.jpg   63mm Crank, Head, and Motor Part-img_2890.jpg   63mm Crank, Head, and Motor Part-img_2891.jpg
fatcaaat is offline   Reply With Quote
63mm, crank, head, motor, part
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
PlanetMinis
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
