| | LinkBack | Thread Tools |
| | #1 (permalink) |
| 1st Gear Member Join Date: May 2007
My Mood: | Removing rust from fuel tanks and parts with electrolysis 650 Rider > > Content > > How to Documents > > Removing rust from fuel tanks and parts with electrolysis My brother sent me this link so I thought I'd send it on to you guys. I haven't tried it yet, have any of you? |
| | #2 (permalink) |
| "High Speed Record Guy" Join Date: Mar 2006 Location: Northern Virginia
| Re: Removing rust from fuel tanks and parts with electrolysis
I'll look into it a lot more before I ever try it. Don't feel like running electricity though a tank that holds gasoline.
| | #3 (permalink) | |
| 3rd Gear Member Join Date: May 2004 Location: New Jersey
| Re: Removing rust from fuel tanks and parts with electrolysis Quote:
Just something to think about the next time you go for a ride... ...and pay close attention when he turns on the key... ![]() | |
| | #4 (permalink) |
| 2nd Gear Member Join Date: May 2007 Location: Maryland 20853
forget all that. do it the old fashion way. Get a chain or a lot of nuts & bolts and start shaking! works like a charm.
| | #5 (permalink) | |
| 3rd Gear Member Join Date: Nov 2003 Location: CT . aaaaaah .... heh heh heh ..
My Mood: | Re: Removing rust from fuel tanks and parts with electrolysis Quote:
Does anybody know how to remove that Kreem sealing stuff from a tank ??? | |
| | #6 (permalink) |
| 1st Gear Member Join Date: Nov 2006 Location: Stillwater
or a corvair.
| | #7 (permalink) |
| 3rd Gear Member | Re: Removing rust from fuel tanks and parts with electrolysis
use por 15 fuel tank treatment...... |
| | #8 (permalink) |
| The Golden Ticket Join Date: May 2006 Location: 5outh 5an 0iego
My Mood: | Re: Removing rust from fuel tanks and parts with electrolysis |
| | #9 (permalink) |
My Mood: | Re: Removing rust from fuel tanks and parts with electrolysis Well I just found this .. What do ya guys think ?? Is it do-able with out big problems or harm to humans or worse our tank paint jobs ?? Vincent Motorcycle Gas Tank and Seat Information vvvvvvv Taken from the above web site .. vvvvvv Removing Tank Sealer: When I acquired my bike, its fuel tank had been coated (probably with Kreem although I'm not certain). Surface prep had evidently not been done correctly, as rust had loosened the coating and chunks were coming looseand ending up in the carbs. This did not enhance performance, and created a fire hazard when debris held the float needle open and the carbs overflowed. Anyhow, Kreem advised me that their product is soluble in acetone, so I bought a gallon at the Home Depot. This worked very nicely; it actually dissolves the coating rather than just softening it, so you can remove all the material if you're patient. Also, acetone is one of the less-dangerous solvents to work with. I'm not sure how universal it is with regard to other brands of coating, but it may be worth a try. Dave Hartner 8/3/02 (thevincent.com does NOT recommend Acetone as a solvent. Use of Acetone is better left to professionals as it is reported to be carcinogenic.) Last edited by JohnnyB; 01-19-2008 at 07:54 PM. |
| | #10 (permalink) |
| "Eating Ramen" Join Date: Feb 2007 Location: Los Angeles, CA
I read the first link carefully and it doesn't say to use gasoline in as the solution. They say to wash out the gasoline with water then alcohol finally drying it. They then say to make a solution with Water and "Arm & Hammer Super Washing Soda" (100% Sodium Bicarbontate). THEN run electricity through it that solution with the sacrificial anode. I've gotta try the acetone to melt the Kreem out of one of my bikes too.I |
| | #11 (permalink) |
| 2nd Gear Member Join Date: Nov 2007 Location: Raleigh, NC
Corvair and pinto have nothing in common. Corvair Corsa is one of the coolest cars ever! |
| | #12 (permalink) |
| PM Newbie Join Date: Apr 2007 Location: Canada
will this process take the pain off a tank ? I have a 91 z50 with a rusty tank, that has pin holes in it so i was thinking about doing this process to clean out the tank ............... |
| Bookmarks |
| Tags |
| electrolysis, fuel, parts, removing, rust, tanks |
| Thread Tools | |
