| | LinkBack | Thread Tools |
| | #1 (permalink) |
| PM Newbie Join Date: Oct 2009
| crf50 gpx 140cc engine help i was thinking about puting an 88cc big bore kit on my crf50 but by the time i spend the money on everything needed it comes out to be as much as the gpx 140cc crated engine. just wantd to kno if anyone knows if this is a good engine? heres the link to it http://shop.pitsterpro.com/gpxmoto140xcrateengine.aspx |
| | #2 (permalink) |
| 2nd Gear Member Join Date: Aug 2008 Location: Kent,OH
My Mood: | Re: crf50 gpx 140cc engine help
yeah they are pretty good engines, i've heard a lot of good things about these, but you may want to check out firepowerminis.com Terry has some yx140's with carb wiring etc....for around $329 I believe. GOodluck |
| | #3 (permalink) |
| Advertiser Join Date: Oct 2006 Location: Flint MI
__________________ If it has my name on it I did it;) FirepowerMinis.com Custom FPM parts and engines. Parts and service for all makes. Honda Trail Bikes parts and accessories. Pitster/Piranha/Thumpstar bikes, parts, engines and accessories. |
| | #4 (permalink) | |
| 1st Gear Member Join Date: Oct 2008 Location: Stevens Point, Wisconsin
My Mood: | Re: crf50 gpx 140cc engine help Quote: JW, why does that engine only have a 22 mm carb on it? Shouldn't it have a 24 or 26 mm on it? | |
| | #5 (permalink) |
Numbers game... It would likely run better on top with a bigger "true" 26mm carb, but the "22" is the same as other oval venturi 24-26's, and they run fine. Parts and jets are easily available. Other than needing a short screwdriver to adjust idle fuel mixture, they're a fine carb. The outlet is 26 as is the manifold. Just the venturi is smaller. TB 20mm has a 20mm outlet, much smaller oval venturi, and make great power, have good response.
| Bookmarks |
| Tags |
| 140cc, crf50, engine, gpx |
| Thread Tools | |
