Go Back   Planet Minis > Forum > General Talk > CRF50
Old 08-26-2009, 04:52 PM   #1 (permalink)
1st Gear Member
eric0177's Avatar
need help with takegawa 124 motor
I have a takegawa motor 124 motor with a kitaco cylinder. It had a kitaco se head on it and I sold it thinking I was going to buy one of the new takegawa r heads. I dont have the money to buy one of the high dollar heads right now and I was wondering does anyone know of a cheaper head that would work on that set up? Like a trail bikes head ect. I am no expert on these motors so I need some help please thanks!!!
eric0177 is offline   Reply With Quote
Old 08-26-2009, 05:03 PM   #2 (permalink)
3rd Gear Member
LongMooie's Avatar
My Mood: Cool
Question Re: need help with takegawa 124 motor
Im confused! you say its a takegawa motor but you have a kitaco124 head and sleave wouldnt this be a kitaco motor, unless theres a takegawa clutch on it but id hardly call that a take motor
the head is going to have to match your 54mm piston
im not even sure if the kitaco piston would work with the takegawa heads???
do a search in the classifieds to see if there are any
takegawa super heads
or kitaco se heads
LongMooie is offline   Reply With Quote
Old 08-26-2009, 08:54 PM   #3 (permalink)
Advertiser
firepower354's Avatar
My Mood: Amused
Yup, or the new TB Honda head with 30mm intake. Pistons made for the combo. Still a few weeks from the catalog, but it's gonna be sweet.
__________________
If it has my name on it I did it;)
FirepowerMinis.com
Custom FPM parts and engines.
Parts and service for all makes.
Honda Trail Bikes parts and accessories.
Pitster/Piranha/Thumpstar bikes, parts, engines and accessories.
Old 08-30-2009, 04:01 AM   #4 (permalink)
PM Newbie
Dogboy's Avatar
My Mood: Mellow
Quote:
When should the new tb head be available?
Any idea on its price?
Any word on how it stacks up against the Kitaco SE or Taki superhead +R?
Dogboy is offline   Reply With Quote
Old 08-30-2009, 09:10 PM   #5 (permalink)
Advertiser
My Mood: Amused
I'll be testing one this week. So far, things sound promising.
__________________
FirepowerMinis.com
Old 08-30-2009, 09:14 PM   #6 (permalink)
2nd Gear Member
twosmoke30's Avatar
My Mood: Amused
wait...so is there gonna be like a v2 for the 50?? and is there gonna be maybe a v3 for the 110??
twosmoke30 is offline   Reply With Quote
Old 09-06-2009, 04:04 PM   #7 (permalink)
PM Newbie
Dogboy's Avatar
My Mood: Mellow
Is this head a crf50 stud pattern compatibile version of the TB Import Race Head (TBW9047)- 30mm intake valve, 23.5mm exhaust valve, 30mm intake port, 25mm exhaust port.
Let us know how it performs.
Old 09-07-2009, 12:14 AM   #8 (permalink)
PM Newbie
Price? I take it this will bolt onto a TB 88cc kit?
ar design is offline   Reply With Quote
Old 09-07-2009, 12:09 PM   #9 (permalink)
2nd Gear Member
My Mood: Mellow
I tested mine this past Sunday and it rips.................I'm thinkin that a S30 cam grind for this head will wake it up. Gonna have a TB300 sent to Crower and have them put the Tak S30 specs on it and I'll let ya know how much more. But the thing rips with the TB300 now. Can you say power wheelies.......
bat999 is offline   Reply With Quote
Old 09-07-2009, 12:38 PM   #10 (permalink)
3rd Gear Member
50rider340's Avatar
My Mood: Cool
terry can you please give us a little more info on this. If they make a roller head for a crf i know what my next purchase might be.
50rider340 is offline   Reply With Quote
Old 09-07-2009, 06:50 PM   #11 (permalink)
2nd Gear Member
My Mood: Mellow
It's not a roller, just a BVH for the CRF.....
Old 09-07-2009, 10:30 PM   #12 (permalink)
PM Newbie
Dogboy's Avatar
My Mood: Mellow
Quote:
What size motor did you fit it to and how does it compare to a SE or +R head?
Old 09-07-2009, 10:57 PM   #13 (permalink)
2nd Gear Member
rc164racer's Avatar
My Mood: Mellow
Im interested in this new head you talk about.
rc164racer is offline   Reply With Quote
Old 09-08-2009, 09:27 AM   #14 (permalink)
2nd Gear Member
Guys.. Im friends with Bat999 and saw the head this weekend. Even helped with a little on the install lol.. Look here is the deal it has the same size valves as the V2 head from TB but has the honda stud spacing.. It uses the TB300 cam but comes with a totally different intake... You could use the 26mm boot or a 28mm boot from any takegawa or Kitaco intake and put it on the TB intake.. (No more funny bolt spacing on the Tb intake on the rubber boot side)..It is not a roller set up.. It has regular rocker arms... The piston is 54mm and is different..It has more of a dome and deeper cut outs for the bigger valves than the current (race head piston). Now we are not using that piston as Bat999 has the TB 95cc 54mm piston (for the old race head) in this bike so we did have to modify his piston a little.. The piston the new head comes with is for the TB 51mm crank... hope that helps a little.. With a good cam this head will be as good as my +R roller head I have from takegawa so yes here is a cheap head that I would put aginst the SE head or the +R.. It just lacks a high lift high duration cam a +R head with a S30 cam would out pull tb300 cam. So for now thats the only thing you might wana source.... We roadrace the bikes so we look for MAX HP #s and run the biggest cams we can... I wana know if the piston works on a 63mm cylinder and a 51mm crank. would it work if you sourced a DR-atv 54mm crank and a 69 cylinder.. Cause if so then you could build a 124cc motor that with the right cam would run with any Jap headed 124 for a LOT less..
taz69 is offline   Reply With Quote
Old 09-08-2009, 11:52 AM   #15 (permalink)
Advertiser
My Mood: Amused
Rollers are hype...
I've mocked-up several combos with the new piston/head setup. It's gonna be popular
The old piston will give lower compression in the new head.
63mm jug and stock crank uses the same piston height as a 51mm crank. Shorter rod. The new piston is a touch shorter, to use the thinner head gasket, is all. 69mm jug and 12v DrATV crank will make an econo-124.
I'm not sure that adding 20 degrees more duration is a good thing, even for a road racer. Maybe scale back to the S25?
__________________
FirepowerMinis.com
Old 09-08-2009, 01:36 PM   #16 (permalink)
2nd Gear Member
S25 is a good cam too.. Firepower would be the contact source for all other info.. Hes the man ...
Old 09-11-2009, 09:15 AM   #17 (permalink)
2nd Gear Member
Hmm well I
124, motor, takegawa
PlanetMinis
