Go Back   Planet Minis > Forum > General Talk > 1973-1985 ATC70 and TRX70
Old 11-18-2009, 02:37 PM   #1 (permalink)
PM Newbie
atc 70 oil pump help!!
Putting a high flow oil pump in my atc70. removed the pump, now how do I remove the shaft? Do I have to remove the stator plate?
84atc70 is offline   Reply With Quote
Old 11-18-2009, 05:56 PM   #2 (permalink)
1st Gear Member
tepco's Avatar
Re: atc 70 oil pump help!!
YouTube - How to Install High Volume Oil Pump
^^^Thanks to arlindsay1992
Why would you have to remove the shaft?
tepco is offline   Reply With Quote
Old 11-18-2009, 06:25 PM   #3 (permalink)
PM Newbie
Thats no good for me. atc 70's have a different shaft then a xr/crf50 and xr/crf70. When getting a aftermarket pump for a atc they give you the pump you would put on a xr or a crf but a different shaft.
Im not sure how to get the shaft out of the motor?
It would be the same way as the xr/crf if that helps.
Old 11-26-2009, 12:55 PM   #4 (permalink)
PM Newbie
Godfried's Avatar
My Mood: Fine
Get a pump for 6V engines, saves you the trouble of having to take your starter mechanism, flywheel, stator and cam chain off to swap the schaft...
You can see the difference on the pictures here (scroll down halfway the page)
Monkey Bike UK - Oil Coolers, Oil Pumps & Breathers
cheers,
Godfried
Godfried is offline   Reply With Quote
Old 11-26-2009, 07:22 PM   #5 (permalink)
PM Newbie
Link does not work
Old 11-26-2009, 08:44 PM   #6 (permalink)
Advertiser
firepower354's Avatar
My Mood: Amused
You can stick a flat screwdriver in the end of the 6v shaft and turn CCW. It will thread out. Slip the 12v conversion shaft in it's place, tighten with needle-nose pliers, install pump. You may have to wiggle things around or pull the stator plate. If you have a stroker, it's ugly...
__________________
If it has my name on it I did it;)
FirepowerMinis.com
810-237-9537 M-F 9-6
Custom FPM parts and engines.
Parts and service for all makes.
Honda Trail Bikes parts and accessories.
Piranha/Medina/Thumpstar bikes, parts, engines and accessories.
atc, oil, pump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
PlanetMinis
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
