1982 Restore Project
This is a discussion on 1982 Restore Project within the 1973-1985 ATC70 and TRX70 forums, part of the General Talk category; I have a 1982 Honda 70 ATC that has been in my basement for about 10 years or more. I took the rear axle out ...
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
    Shutt24's Avatar
    Jan 2010
    Greensboro, NC.
    I have a 1982 Honda 70 ATC that has been in my basement for about 10 years or more. I took the rear axle out when I first got it to replace the rear bearing and seals. I have decided to start back on the this project and try to get it completed before summer. I am going to completely strip it down to the frame, bead blast it and repaint. I would like to go back with factory colors if possible. I was hoping someone could give me some information on color codes and were to purchase paint. I know it needs red, black and grey. I have read many of the restoration posts and see that there are many experts on this forum. I'm sure I will be requesting information from many of them. I will post some photos over the weekend.
    crfiddy02's Avatar
    Aug 2009
    pa
    Re: 1982 Restore Project
    this is a good question ! i got a blue one and wanted to do same thing ! good luck with build!
    Shutt24's Avatar
    Jan 2010
    Greensboro, NC.
    The trike is completley stripped now. I am going to start bead blasting this week. The gas tank needs some repair, it is a little rusted in the bottom. I took a dremel tool with a cutting wheel cut tank into an upper and lower part. I am going to bead blast the entire tank, fix the rusted out metal and weld back together. I will probably seal the inside with something not for sure what yet. I have a little Por-15 left I may try that, not for sure if it will hold up in a gas tank.
    is Looking for crf50 12 bar
    tblumer's Avatar
    Mar 2009
    Syracuse NY
    Por15 works great
    LouK's Avatar
    Aug 2009
    whats por-15 does it seal the inside of a tank like that kreem stuff
    tblumer's Avatar
    Mar 2009
    Syracuse NY
    tmas's Avatar
    Apr 2005
    TO
    Quote Originally Posted by LouK
    yes...
    POR15, Inc. - Stop Rust Permanently - Repair Gas & Fuel Tanks
    Shutt24's Avatar
    Jan 2010
    Greensboro, NC.
    Here are a few pics of the tank before blasting. They are cell phone pics so they are not good quality.
ID:	52452   Click image for larger version.
ID:	52453   Click image for larger version.
  10. #9
    LouK's Avatar
    Aug 2009
    thanx tblumer nice stuff that por15 may need that for some of my tanks
  11. #10
    50minikid's Avatar
    Oct 2007
    Bothell, WA
    Quote Originally Posted by crfiddy02
    If you have a special edition blue one you should keep it blue. Just my opinion
  12. #11
    Shutt24's Avatar
    Jan 2010
    Greensboro, NC.
    I split the cases last night just to make sure everything looked good. Will need to replace all the shaft seals. Everything else looked good. Some of the gears and washers fell out but think I can put back in correctly if my schematic is correct.
ID:	52486   Click image for larger version.
ID:	52487   Click image for larger version.
ID:	52488   Click image for larger version.
  13. #12
    tblumer's Avatar
    Mar 2009
    Syracuse NY
    ALL_ATC70_1983 PARTS_DIAGRAMS this page has schematics, I have some PDF files of the shop manual. Pm me your email address and I'll shoot you over whatever I have.
  14. #13
    tblumer's Avatar
    Mar 2009
    Syracuse NY
    I split the cases on my motor to add a kickstart, it's not too bad to slap back together
  15. #14
    Shutt24's Avatar
    Jan 2010
    Greensboro, NC.
    Kick starter would be cool. Is that after market or from a Honda 70 trail bike?
  16. #15
    tblumer's Avatar
    Mar 2009
    Syracuse NY
    Yeah I used a ct70 kicker and sidecover. I dropped a lifan 140 into my atc70, gonna use the 70 motor on some other project.
replace rear axle bearing trx70
