Atc 70 Will Not Fire
This is a discussion on Atc 70 Will Not Fire within the 1973-1985 ATC70 and TRX70 forums, part of the General Talk category; ATC 70 3 wheeler Restored engine rings, cam chain tensioner gasket set brakes bearings etc Bike ran good untill My son tore the bike apart ...
Results 1 to 5 of 5
    jgreg's Avatar
    Apr 2011
    Bike ran good untill My son tore the bike apart to sand blast and paint frame and fenders
    Since then it will not fire It has points and condenser that are new changed out after not be able to get it to fire
    This is what it does do I can hold the coil wire in my hand and when the recoil starter is pulled it will knock the crap out of me but still not fire thru the spark plug tried several plugs also stuck plug into end of coil wire by passing the spark plug cap
    Any and all suggestions etc appreciated
    Thanks in advance
    Jim
    tmas's Avatar
    Apr 2005
    TO
    tmas's Avatar
    Apr 2005
    TO
    This may help.......Make sure the coil is grounded to the frame....... Sand the paint off where it contacts frame...... Check the wiring with the diagram below.
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Also sand down the frame where the engine mount holes are, the engine may not be grounded to the frame.
    - dirtbkr188 -
    jgreg's Avatar
    Apr 2011
    I know have another parts bike atc 70 and a trx 70 so that equals 2 atc 70 s and 1 trx 70 but know will run
    Ok I took the top coil off the bikes 2 of them brought them to shop and had them tested one had very good fire and one very weak fire.
    The one that had weak fire I peeled the coil wire back to naked wire and spark jumped from the end of the naked wire to the fins on the head but when put on a known good plug and cap will not fire thru Any sugestions please post up
    Thanks in advance Jim
1985 atc 70 wiring diagram
1985 honda atc 70 no spark
1985 honda atc 70 wiring diagram
70cc honda 3-wheeler coil wireing
atc 70 no spark
atc 70 not getting fire
honda atc 70 wiring
no fire honda 1973 atc 70
no spark atc70
