1985 Honda ATC 70 No Fire!
This is a discussion on 1985 Honda ATC 70 No Fire! within the 1973-1985 ATC70 and TRX70 forums, part of the General Talk category; I have a 1985 Honda ATC 70 that is not firing I baught it just put on a new strator, points, and condencer. as well ...
Results 1 to 9 of 9
    bigfuller2011's Avatar
    Oct 2012
    I have a 1985 Honda ATC 70 that is not firing I baught it just put on a new strator, points, and condencer. as well as coil and plug. If anyone has any ideas on anything it could be PM or reply please help. Thanks, bigfuller2011
    tmas's Avatar
    Apr 2005
    TO
    Are you getting a good ground?
    Oct 2012
    I should be. Ive literally tried everything I know this is my 2nd atc and its in excellent shape cosmetically just not firing. I usually deal with the Z50.
    tmas's Avatar
    Apr 2005
    TO
    If you have tried everything download this 1985 ATC70 manual & go through it.
    ATC 70 Shop Manual 1985 - ATC 70 Manuals - Sterdy Products
    is thinking of upgrading the '74
    XR75
    vintagemx's Avatar
    Oct 2011
    Seattle
    Did you unplug the kill switch?
    is fast = 2 money and pain?
    fastatc70's Avatar
    Jun 2012
    Northbrookfield, MA
    The kill switch, is very possible and does the motor have a neutral safety switch?. Is it grounded?
    tmas's Avatar
    Apr 2005
    TO
    ATC no start
    Got this from the manual if it will help you.
    dnicoll's Avatar
    Mar 2013
    I have had loadsa trouble with mine!
    U got decent spark?
  10. #9
    justmefilm's Avatar
    Feb 2017
    Richmond, BC. Canada
    Did you ever solve the problem with no spark? I'm having the EXACT same problem.
  1. 1985 Honda ATC 250R Missile Engineering
    By lumpdog256 in forum Complete Bikes For Sale - All makes and models
    Last Post: 07-21-2010, 04:07 AM
  2. 1985 Honda CT70
    By rippinthez50 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 01-14-2010, 07:00 PM
  3. 1985 Honda Z50R
    By njdpo in forum Z50, CT70, ZB50 and other Honda Parts
    Last Post: 01-13-2010, 10:10 AM
  4. My 1985 Honda Z50 pics inside
    By Roosey2 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 05-06-2009, 10:16 PM
  5. 1985 Honda z50 runs sometimes
    Last Post: 06-08-2006, 09:07 PM
1985 atc 70 wont start
1985 honda atc 70
1985 honda atc 70 coil
1985 honda atc 70 no spark
1985 honda atc 70 wont start
atc 70 no fire
atc 70 wont start
honda 70 atc no spark
honda atc 70 will not run
honda trx 70 wont start
why wont my 73 honda 70cc have spark
