1980 ATC70 Restore Project #4
This is a discussion on 1980 ATC70 Restore Project #4 within the 1973-1985 ATC70 and TRX70 forums, part of the General Talk category; Friends, This is just a tragedy. Such severe neglect and abuse. As a father of three other ATC 70's, it broke my heart when I ...
Results 1 to 12 of 12
    a7t0c's Avatar
    Aug 2013
    Friends, This is just a tragedy. Such severe neglect and abuse. As a father of three other ATC 70's, it broke my heart when I came across the pathetic plight of this 1980 ATC 70. Please send prayers for this bike. I may be able to help the outward appearance, but I worry about the emotional toll. There she sat for 20+ years in a barn. Unfed, unkempt, rusting away into a certain destiny of the scrap pile. Even in her dilapidated condition the owner would not take less than $100 for this rusted mess. The gas tank, frame, pull start, and a few other pieces can be salvaged, and she has foot peg guards; so my heart strings tugged and I brought her home with me. She'll be ATC 70 restore project #4. She's unique in that my other three are 1984's. I probably won't do too much work until the spring/summer but at least I've got another project bike and I'll update you all with any progress made.
ID:	171878Click image for larger version.
    hondaatc70's Avatar
    Nov 2015
    ohio
    Where was this one at?
    a7t0c's Avatar
    Aug 2013
    Quote Originally Posted by hondaatc70 View Post
    This one was in Utah.
    is Tinkering
    mrrcx's Avatar
    Jun 2011
    Westlake Village, CA
    Craigslist be like: "fresh oil change!"
    a7t0c's Avatar
    Aug 2013
    Quote Originally Posted by mrrcx View Post
    that's funny right there ^^^^^^^^
    a7t0c's Avatar
    Aug 2013
    1980 atc 70
    Well it only took about four months, but I got the surgery table out and started the tear down of this project.
    a7t0c's Avatar
    Aug 2013
    ATC 70 Electrolysis rust removal - gas tank
    I got the gas tank exterior looking good but the inside needed work.
ID:	175717Click image for larger version.
    After shaking the tank with the nuts inside it I dumped out the nuts and a lot of rust.
    Next I capped the fuel drain tubes and poured some Loctite rust remover into the tank. I sloshed it around to coat the entire inside and let it sit for a while before flushing out the tank.
    As I type, the tank is out in the garage going through the first round of electrolysis rust removal.
    I mixed up some arm and hammer wash soda (electrolyte) with water and filled the tank. Then I positioned a metal electrode such that it won't contact the sided of the gas tank. Then I hooked up the battery charger. As soon as I did the solution began bubbling and you know that electricity is being conducted from the side wall to the electrode. It carries the rust with it and it attaches to the electrode.
    a7t0c's Avatar
    Aug 2013
    There's a lot of rust in this tank.
    Here's the two hour check, overnight check, cleaned anode, and a random check.
ID:	175770   Click image for larger version.
ID:	175771   Click image for larger version.
ID:	175772   Click image for larger version.
  10. #9
    a7t0c's Avatar
    Aug 2013
    Gonna keep at it until no more rust is left.
  11. #10
    is getting called a greaser
    because of how his Z50 looks
    dventu's Avatar
    Jan 2014
    California
    Be careful. The tank might get pinholes. That's how I screwed up my tank.
    Sent from my SM-G925I using Tapatalk
  12. #11
    a7t0c's Avatar
    Aug 2013
    Quote Originally Posted by dventu View Post
    Yep, it opened up 5 small pinholes that I'm dealing with. I tried to weld them and made it worse. Now I'm looking at a fiberglass or brazing repair for it.
  13. #12
    dventu's Avatar
    Jan 2014
    California
    Brazen it. Fiberglass won't work asking me how I know
  1. Honda atc 70 restore project #3
    By Crappie Master in forum 1973-1985 ATC70 and TRX70
    Last Post: 04-05-2016, 08:56 AM
  2. 1980 atc70
    By monkeybike_mike in forum Complete Bikes For Sale - All makes and models
    Last Post: 06-10-2015, 08:25 PM
  3. Forsale 1980 Z50r Restore in PA.
    By Ready2Fight in forum Complete Bikes For Sale - All makes and models
    Last Post: 08-15-2010, 07:09 AM
  4. atc70 1985 gas tank restore
    By wheredahoesatracing in forum 1973-1985 ATC70 and TRX70
    Last Post: 07-26-2009, 03:31 PM
  5. restore project
    By badkippy in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 10-23-2006, 07:52 PM
Tags for this Thread
