Lighting problems
This is a discussion on Lighting problems within the 1988 ZB50 and ZB Import Replica Bikes forums, part of the General Talk category; Issues...... can anyone tell me if on the Zb, all the lights on the bike seem to go with rpms {low idle= dim lights, high ...
Results 1 to 7 of 7
    Zimmerman's Avatar
    Jun 2012
    Lighting problems
    Issues...... can anyone tell me if on the Zb, all the lights on the bike seem to go with rpms {low idle= dim lights, high idle= bright lights} I'am hoping its not the alt or stator....Thanks in advance for saving me a lot of $$$$$$
    is in need of more ZB50's
    tmas's Avatar
    Apr 2005
    ...otnoroT...
    How is your battery voltage? Everything will work without a battery but without it sometimes requires a few rpm's. Put a new battery in or charge it...... you won't believe the difference.
    Zimmerman's Avatar
    Jun 2012
    So your saying that is somewhat normal on the honda for it to dim? how often does it need to be charged.On a side note whats the point of having the battery? If it runs without it?????I was telling my buddy it had one, he didn't believe and i didn't have an answer for it....... please enlighten me
    tmas's Avatar
    Apr 2005
    ...otnoroT...
    Yes, it will dim without a battery. Batteries at the most last a year or two. The reason for the battery is because it is a street legal bike and if the motor dies and does not produce power you have no lighting.The signal lights and horn will work off battery power when the motor is not running. With the battery power you, will have some lighting at the side of the road. Better some than none. Safety issue. Hope this makes sense.
    Zimmerman's Avatar
    Jun 2012
    Perfect.... Thanks wise one..
    tmas's Avatar
    Apr 2005
    ...otnoroT...
    Having a battery will also reduce the stress on the stator.
    ZB50 Battery/ box
  7. #7
    Zimmerman's Avatar
    Jun 2012
    tmas your knowledge impressive, my zb would love to have you as a neighbor so it wouldn't have go threw the learning curve
  1. yx150 lighting? ricky stator tusk lighting kit
    By Xare50 in forum Chinese/Import Minis - General Discussion
    Last Post: 07-02-2012, 04:25 PM
  2. Lighting
    By Gixxer1K87 in forum KLX110, DRZ110, TTR90
    Last Post: 04-07-2010, 03:51 PM
  3. lighting kit
    By leirhiht in forum Chinese/Import Minis - General Discussion
    Last Post: 12-12-2009, 07:20 AM
  4. Lighting kit
    By i_roll_on_10s in forum Bikes and Parts Wanted - All Makes
    Last Post: 12-30-2008, 09:39 AM
  5. Z50 lighting
    By SprNtrl in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 11-19-2005, 05:37 PM
high idle with bright lights
