ZB50 carburetor questions
This is a discussion on ZB50 carburetor questions within the 1988 ZB50 and ZB Import Replica Bikes forums, part of the General Talk category; I recently purchased a ZB50 and took the carb off to clean it. Upon disassembly I noticed there was no air box and that someone ...
Results 1 to 8 of 8
    theoilman's Avatar
    Mar 2016
    Bellingham, WA
    I recently purchased a ZB50 and took the carb off to clean it. Upon disassembly I noticed there was no air box and that someone had fitted an old style Z50 air cleaner on it. I didn't think anything of it until I was putting a new gasket kit in it. The gaskets did not work on my carb, so upon further research it looks like a z50 or Z50R carb has been installed.
    I am a bit of a stock purist where it makes sense so I would like to put a stock air box back in (I have found one for sale) but my question is does anyone know if the Z50 carb is a good option for this engine and will it fit with a stock air box? I don't know if the throat or the length is the same size.
    Another option would be to find a stock carb but this one cleaned up well in my ultrasonic cleaner and if it is a good option I might as well use it.
    Thanks in advance for any help/advice.
    tmas's Avatar
    Apr 2005
    TO
    How did you make out? The Z50 carb is probably the same size as the ZB. Measure your carb where the air filter goes on and I will measure a ZB carb for you.
    theoilman's Avatar
    Mar 2016
    Bellingham, WA
    Thanks Tmas, I will try to measure it tonight. I will also try to get some pictures posted in the next couple weeks.
    theoilman's Avatar
    Mar 2016
    Bellingham, WA
ID:	174573Click image for larger version.
    It looks like the air cleaner side is about 28mm and the length of the carb is about 69mm, will this work with a stock air box?
    Thanks,
    Paul
    tmas's Avatar
    Apr 2005
    TO
    Carb length is 71 mm.
    tmas's Avatar
    Apr 2005
    TO
    The air filter side is 35 mm.
    theoilman's Avatar
    Mar 2016
    Bellingham, WA
    Thanks for the measurements, it looks like I need to be looking for a new carb. I have an air box coming though.
    nolarocks's Avatar
    Feb 2014
    Where did you get your airbox? I am starting a teardown and rebuild - trying to find as many oem parts as possible.
  1. New ZB50 Owner. Pictures and Questions.
    By tigers486 in forum 1988 ZB50 and ZB Import Replica Bikes
    Last Post: 03-18-2013, 12:05 PM
  2. ZB50 Build Research Questions Thread
    By ShapeShifter in forum 1988 ZB50 and ZB Import Replica Bikes
    Last Post: 09-05-2009, 10:26 AM
  3. New ZB50 Owner, few questions
    By pathfinder in forum 1988 ZB50 and ZB Import Replica Bikes
    Last Post: 10-02-2007, 10:33 AM
  4. ZB50 to a NSR Conver. Questions Ive got the feaver
    By jmurray192 in forum 1988 ZB50 and ZB Import Replica Bikes
    Last Post: 10-08-2006, 10:56 AM
  5. Some issues and questions about my ZB50
    By RickyCRX in forum 1988 ZB50 and ZB Import Replica Bikes
    Last Post: 06-16-2006, 01:59 PM
carburetor
zb50
