Carb question
Carb question
This is a discussion on Carb question within the 1988 ZB50 and ZB Import Replica Bikes forums, part of the General Talk category; Looking for a float bowl gasket for the original ZB carburetor. I ordered this kit 16010-141-305 from the dealer but float bowl gasket was incorrect. ...
Results 1 to 12 of 12
Thread: Carb question
    Nobody's Avatar
    Jan 2012
    Carb question
    Looking for a float bowl gasket for the original ZB carburetor. I ordered this kit 16010-141-305 from the dealer but float bowl gasket was incorrect. I did a search but couldnt find anybody having the same problem. Any info appreciated.
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    - dirtbkr188 -
    kirrbby's Avatar
    Aug 2014
    Davison Mi.
    Quote Originally Posted by Nobody View Post
    How far off is it?? I'm thinkin you just need to snip a little...extra bit, off of it... In other words, compare to your old one and just snip off the part that is unnecessary.
    Nobody's Avatar
    Jan 2012
    Sorry i havent posted a pic im not exactly sure how to. kirrbby i did snip the piece of gasket off you are talking about but the gasket didnt seem to fit the bowl correct. It didnt have good crush and started seeping after couple days. Perhaps ive done something wrong.
    kirrbby's Avatar
    Aug 2014
    Davison Mi.
    Ahh, I'm not positive that it worked for me, but I think that's what I did. Maybe I had a different kit. If you're not able to post up pics, post up the numbers off of the carb. Maybe someone can help you figure it out.
    >>>also, be absolutely sure you know WHERE the fuel is seeping from.
    kirrbby's Avatar
    Aug 2014
    Davison Mi.
    This is what I come up with. shows the same part # for the bowl gasket as the ones linked above.
    16010-141-305 GASKET SET $24.41
    seaturtle's Avatar
    Feb 2015
    I just put in the same kit. I cut off the little tab on the bowl gasket. Haven't run gas through it yet. Hope it works
    Nobody's Avatar
    Jan 2012
ID:	198937Click image for larger version.
    Sent from my SM-G386W using Tapatalk
  10. #9
    Nobody's Avatar
    Jan 2012
    Original float bowl gasket on left and new one from kit on right.
  11. #10
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Judging by the thickness of the OEM one, I'd say the groove in the float bowl has to be too deep for the one on the right. That being said, I wonder is an XR/CRF70 float bowl would work for you.
    - dirtbkr188 -
  12. #11
    tmas's Avatar
    Apr 2005
    TO
    Did you ever find a fix for this?
    Nobody's Avatar
    Jan 2012
    No I didn't. I used a "cut to size" Oring kit and just bonded it together. Working good so far.
  1. CT70 with YX140 with 26mm carb question (carb adjustment??)
    By FrankyArseneau in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 11-24-2016, 11:22 AM
  2. VM 26mm carb question and electrical question
    By Fast Freddy in forum Chinese/Import Minis - General Discussion
    Last Post: 04-22-2010, 04:37 PM
  3. carb question
    By vietladin in forum Stunt Minis
    Last Post: 02-26-2009, 12:36 AM
  4. Carb Question: ATC 200 carb and 140cc motor
    By muxster in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 10-06-2008, 02:28 PM
  5. yet another carb question
    By boost in forum CRF50
    Last Post: 06-15-2004, 12:03 AM
