Speedometer gear removal
This is a discussion on Speedometer gear removal within the 1988 ZB50 and ZB Import Replica Bikes forums, part of the General Talk category; I'm in the process of restoring my ZB 50 and where I have pretty much everything sandblasted I'm having trouble figuring out how to remove ...
Results 1 to 8 of 8
    badkippy's Avatar
    Feb 2005
    Bemidji mn
    I'm in the process of restoring my ZB 50 and where I have pretty much everything sandblasted I'm having trouble figuring out how to remove the speedometer gear from the front brake hub. Anybody else come across this?
    tmas's Avatar
    Apr 2005
    TO
    Is this thread any help to you?
    Zb Speedo Gear/hub
    badkippy's Avatar
    Feb 2005
    Bemidji mn
    It's the gear inside of the hub I'd like to remove for blasting and powder coating.
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    It could just be stuck to the inside of the hub with old grease, maybe try using a pair of water pump pliers to jiggle it loose while pulling on the pliers.
    - dirtbkr188 -
    badkippy's Avatar
    Feb 2005
    Bemidji mn
    I'll try that tomorrow. Thanks
    kirrbby's Avatar
    Aug 2014
    Davison Mi.
    There are 2 gears that are in the brake plate. One is big and falls out easily. The other is a little tricky. Which are you trying to get out. The second, if I remember right, has a set screw that holds it in....I'll have to try to remember how to pull it out. I think it's splined, and comes out toward the outside of the brake plate.
    badkippy's Avatar
    Feb 2005
    Bemidji mn
    That's exactly what I'm after. I'd like to blast and powdercoat it with the rest of my parts.
    kirrbby's Avatar
    Aug 2014
    Davison Mi.
  1. TB Primary Gear Clutch Removal install help???
    By KLX110mx40 in forum KLX110, DRZ110, TTR90
    Last Post: 10-19-2015, 09:44 PM
  2. Speedometer Drive Tang Removal?
    By ShapeShifter in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 07-20-2012, 08:06 PM
  3. timing gear cover removal
    By dcrawf36 in forum Honda CRF70
    Last Post: 03-14-2009, 05:06 AM
  4. drive gear or removal spacer?
    By klx110racer in forum KLX110, DRZ110, TTR90
    Last Post: 01-11-2009, 08:25 PM
