KX60 rear wheel question...(don't know what Happened)
This is a discussion on KX60 rear wheel question...(don't know what Happened) within the 2 Stroke Pitbikes forums, part of the General Talk category; Hello again. Don't know what happened but I posted this question earlier today and was able to sign in no problem, then this afternoon my ...
Hello again. Don't know what happened but I posted this question earlier today and was able to sign in no problem, then this afternoon my account did not exist.
So here goes again.... Son's 99' needs a rear wheel badly and I found two on ebay. One is from an 83' and the other is from an 86'. Will either of them fit the 99'? Thanks again for your help.
10-13-2010 05:05 PM
Re: KX60 rear wheel question...(don't know what Happened)
im pretty sure ALL the kx 60's were the same we had a pair of 85's and they look just like the newer ones the dealer should be able to give you the part number of the wheel itself complete if he cant get the pn for the hubs and see if theyre the same good luck brad
should be the same the older will have a black hubs
Hey thanks guys! I was thinking the same thing just wanted to be sure before I bid on them.
Thanks again! Diego
- You may not post replies
- You may not edit your posts
Forum Rules
