1981 cr80
1981 cr80
This is a discussion on 1981 cr80 within the 2 Stroke Pitbikes forums, part of the General Talk category; i want to know if 81 cr80 forks will bolt directly onto a 2001 xr100. i have heard they d just need conformation. also whats ...
Results 1 to 4 of 4
Thread: 1981 cr80
    ryan13254's Avatar
    Mar 2012
    1981 cr80
    i want to know if 81 cr80 forks will bolt directly onto a 2001 xr100. i have heard they d just need conformation. also whats the difference in the 81 forks vs the xr100 forks. are the alot longer? thanks
    ryan13254's Avatar
    Mar 2012
    Anybody?
    Luckystar64's Avatar
    Feb 2007
    Brunswick, Ohio
    I don't think they're much different. They may have valves on the caps to release built up air pressure. They wouldn't be a huge upgrade. I'd grab something with a disc brake if I were going to bother at all with it. --L*64
    theraymondguy's Avatar
    May 2010
    Niagara, ON
    Quote Originally Posted by ryan13254 View Post
    The CR80 forks are longer and larger diameter than the XR80/100. You'll have to swap out the lower bearing on the stem from the XR to the CR stem, no you can't use the XR tripples on the CR forks. I'd recommend you get an taper bearing kit as the loose balls and races are a pain in the a$$.
    The CR forks will take more weight and rebound nicely compared to the XR's, but yeah, they're quite a bit longer. CR80R forks are charged, or are meant to run pressurized with air (or nitrogen if you're stinkin' rich). If you're lucky your donor will come with the front wheel. If so, you'll also note that the front drum brake is larger, you'll need a 1980-1984 CR80 brake cable (got mine last year from Motion Pro).
    The only year CR80R with disc brake that's a bolt on is 1986, a one year only deal that didn't have the best suspension.
    1998 XR100R with 1984 CR80R front end.
    BBR's heavy duty spring set and proper fork oil vs. ATF might be a lot less trouble than the CR forks, tripples.
    If you go with the CR forks, then you'll want to level out the rear and more power, better exhaust, bigger rear shock... it gets to be a disease...
  1. 1981 jr 5o dies out
    By PBR188 in forum 2 Stroke Pitbikes
    Last Post: 02-10-2011, 11:02 PM
  2. 1981 yz60
    By cripto_valentine in forum Roost Area
    Last Post: 10-24-2009, 07:27 PM
  3. 1981 Z50r
    By jheckert in forum Z50, CT70, ZB50 and other Honda Parts
    Last Post: 10-01-2007, 06:04 AM
  4. 1981 z50 parts
    By hoerter2158 in forum Z50, CT70, ZB50 and other Honda Parts
    Last Post: 04-29-2007, 07:15 PM
  5. 1981 Ktm250gs
    By aclark092 in forum CRF50/CRF70 Parts For Sale
    Last Post: 07-18-2006, 09:29 AM
1981 cr 80
1981 cr80
1981 cr80 forks
1981 cr80 shock length
1981 cr80 shock springs
1984 cr80 pics
cr 80 forks
cr80r forks
decked out honda cr80r
does a 2001 cr80r have fork
spokane craigslist
xr100r bbr back spring
