Modified BW80 Yamaha - Page 56
This is a discussion on Modified BW80 Yamaha within the 2 Stroke Pitbikes forums, part of the General Talk category; The Big Wheel looks factory new! Good job. As far as the crash I had the same thing happen to me but I was in ...
Page 56 of 56 FirstFirst ... 646545556
Results 826 to 836 of 836
Like Tree215Likes
Thread: Modified BW80 Yamaha
  1. #826
    234wheeler's Avatar
    May 2009
    So Cal
    The Big Wheel looks factory new! Good job. As far as the crash I had the same thing happen to me but I was in a Landcruiser. The guy was 90! He cut me off and if I hadn't actually hit him I would have rolled. Man there's some really bad drivers in So.Cal!
  2. #827
    cheeseyboy's Avatar
    Oct 2015
    I was riding my 07 KLX250S, bringing it in for the first inspection. I just got it a month ago, got it at a decent price. I was hit on the right side. It was one of those slo-motion things going on. First time getting hit on the street. EVERYONE is telling me to give up riding. I'm not sure I can do that.
  3. #828
    harleykids's Avatar
    Oct 2016
    question...for the fastace shock mod, everyone says to drill a new shock mount hole 3/4" behind the stock mounting hole. Is this necessary, due to the short top mount on the fastace shock? Or is this just to raise the rear end of the bike by 2"? Just curious, if I want to keep the stock height of the rear, and simply replace the soft OEM shock (made for a small person) with an adult weight capacity shock (fastace 550 as mentioned) can I simply bolt on the shock in the stock hole? Or is the top of the shock too short to reach the stock mounting hole?
    I cut custom spacers to stiffen up my front forks for adult riders, and they work great. Now I need to stiffen the rear suspension of the bike to match.
    Don't want to raise the rear, just stiffen it. I also run the original oil tank, and don't plan on getting rid of it anytime soon, so the fastace resevoir shock that is mentioned on this forum thread may not work for me with the stock oil tank. I will try to find a stiffer 11" eye to eye shock that has a long top mounting design like the stock BW80 shock.
    Any ideas?
    thanks!
    234wheeler's Avatar
    May 2009
    So Cal
    It should bolt up. The spring diameter isn't any bigger than stock so the oil tank shouldn't be an issue. You need some washers to use for spacers on the shock and you could offset the shock away from the oil tank if it's too close. I recommend getting the heavy fork springs. Together with the shock it handles the rough stuff really well.
  6. #830
    is glad the stupid thing runs!
    PUBCRAWL's Avatar
    Mar 2015
    Ontario, Canada
    Quote Originally Posted by harleykids View Post
    Any ideas?
    thanks!
    You don't have to change the mount hole but I would recommend it.
    I had to flip the shock around to get the reservoir to clear the oil tank on my bike and that was with the changed mounting hole. I would also recommend the heavier fork springs I think PW's Only have them.
  7. #831
    harleykids's Avatar
    Oct 2016
    yeah, so therein lies the problem. The fastace 550lb inch shock with built in resevoire is not meant to be run upside down.
    and the resevoire looks like it will definitely hit the stock oil tank, no doubt about it.
    Anyone know of a remote resevoire fastace 550lb inch shock? Or another shock without a resevoire that would work for an adult?
    And no need to buy new springs for the front forks....1" PVC sched. 40 spacers work perfectly for adult riders! $0.25 worth of material!
    I heard the KTM 65 shock may work, but same issue, it has a resevior too?
    Any other ideas? I may just try a honda 11" eye to eye shock from a CB400 or something.
  8. #832
    234wheeler's Avatar
    May 2009
    So Cal
    Non reservoir shocks need to have the shock body in the up position to work correctly. Reservoir shocks can be mounted in any position and still operate correctly. The reason most are mounted body up is to save on unsprung weight. This info is from the Works Performance shocks website. Adding a spacer to your fork springs will add preload to the spring and will change the ride height but will not change the spring rate.
    PUBCRAWL likes this.
  9. #833
    Big specht's Avatar
    Oct 2008
    Where do you get heavier springs for these forks? I have acouple of these bikes and would like to stiffen up the suspension. How does heavier fork oil seem to work ?
  10. #834
    AK mini rider's Avatar
    Nov 2016
    My pitster came with super thin shock oil. Just a guess. But I'm thinking somewhere in the 5-7.5 wt neighbor hood and had 125cc in it. It would bottom out crazy easy. I put in 175cc of 15wt and what an amazing difference. It is about perfect now. Same ride height. A little stiffer and slower performance that doesn't bottom out at all now. Maybe worth a shot before going to heavier springs.
  11. #835
    surveywaters's Avatar
    Nov 2011
    Cayce, SC, USA
    I saw it asked once with an "i'm pretty sure" answer. But I'd like something more specific. Will the footrest off a PW80 fit the bw? Also, is there a difference between the PW seat and the BW seat other than where they meet the fuel tank? I am in need of most body work and am considering a china PW set with fenders, seat and tank. I no there are a few things that need done but it's not gonna be cost effective if I still have to find a bw seat.
  12. #836
    67camaro496's Avatar
    Apr 2016
    The foot pegs are the same but everyone upgrades to the cleated ones you can get on pwonly.com. Per previous post on this thread plastics will fit with modifications but are not the same as the bw obviously due to big wheels/tires. Look through this thread as someone actually did it.
  1. Anyone Interested In A Stock Bw80?
    By vstaffa in forum Complete Bikes For Sale - All makes and models
    Last Post: 05-09-2011, 10:47 PM
  2. WTB: yamaha bw80 or bw200 in good condition
    By jtp in forum Bikes and Parts Wanted - All Makes
    Last Post: 05-25-2010, 02:25 PM
  3. 2 yamaha big wheel 80 bw80 in ny
    By damageinc2785 in forum Complete Bikes For Sale - All makes and models
    Last Post: 02-02-2009, 07:38 AM
  4. Yamaha bw80
    By theeechozen1 in forum CRF50
    Last Post: 04-14-2007, 01:06 PM
  5. WANTED: Rear fender for Yamaha BW80
    By Erichsen229 in forum CRF50/CRF70 Parts For Sale
    Last Post: 02-22-2005, 10:17 PM
bw 80
bw80
bw80 for sale
bw80 forum
modified yamaha bw80
pw80 mods
yamaha big wheel 80 specs
yamaha bw80
yamaha bw80 for sale
yamaha bw80 forum
yamaha bw80 parts
yamaha bw80 specs
