Lacing RM 85 Wheel
Lacing RM 85 Wheel
This is a discussion on Lacing RM 85 Wheel within the 2 Stroke Pitbikes forums, part of the General Talk category; I am relacing a Suzuki rm 85 rear wheel. The spokes are two different lengths. Can anyone help with this?...
Results 1 to 4 of 4
    sox and martin's Avatar
    Oct 2006
    Winnipeg Canada
    Lacing RM 85 Wheel
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    There are inner spokes and outer spokes, some are laced from the outside in, the others from the inside out. Sometimes the hub ends of the spokes have slightly different bends to them as well.
    If the hub has two vastly different diameters between the sprocket side and the brake side, the longer spokes go on the smaller diameter side, and the shorter spokes go on the larger diameter side, if that makes sense.
    - dirtbkr188 -
    Oct 2006
    Winnipeg Canada
    There is a difference of diameter in the hub form one side to the other. The sprocket side being the larger.
    is doin' jumps
    VillainMotorsports's Avatar
    Feb 2007
    Winnipeg, Manitoba, Canada
    Sprocket side would use the shorter spokes. Just make sure there isn't actually 4 different lengths, inners and outers (they'll be a difference by about 2mm) for each side. Sometimes inners and outers will be the same length, depends on the hub configuration.
    Instagram: Hidden Content
    Facebook: Hidden Content
  1. Wheel Lacing
    By fiftynutsrider in forum Chinese/Import Minis - General Discussion
    Last Post: 03-04-2011, 08:09 PM
  2. re-lacing rear wheel
    By zachvu in forum Chinese/Import Minis - General Discussion
    Last Post: 05-27-2009, 07:24 PM
  3. WHEEL LACING
    By SLAPAHO in forum KLX110, DRZ110, TTR90
    Last Post: 04-04-2005, 10:32 AM
  4. Wheel lacing problems
    By Jetster220 in forum CRF50
    Last Post: 06-22-2004, 10:49 AM
  5. Lacing the rear wheel
    By Fireball929 in forum CRF50
    Last Post: 11-03-2003, 05:38 PM
