will cr 85 forks fit on a crf150f
This is a discussion on will cr 85 forks fit on a crf150f within the Bigger Minis Forum forums, part of the General Talk category; I have a crf 150 f i ride it on the track than on thee trials. I want a softer setup. Will cr 85 forks ...
Results 1 to 8 of 8
    crf 150 f's Avatar
    Feb 2009
    I have a crf 150 f i ride it on the track than on thee trials. I want a softer setup. Will cr 85 forks and rear shock fit on a crf150f or should i some other shocks.
    is out of business
    dirttrackin280h's Avatar
    Aug 2006
    Oakley, California
    Re: will cr 85 forks fit on a crf150f
    Looking for a softer setup? How much do you weigh? The stock 150f suspension is very plush.
    Yes CR85 forks will bolt onto your 150F with some mods.
    If you have an 06'-09' 150F with Electric-start than the CR85 rear shock will NOT work since the battery box is in the way of the reservoir on the 85 shock.
    I'm not sure how much $$ you have to spend on this type of setup, but just to give you a figure...The CR85 fork swap will cost you anywhere from $800 and up/ depending how much you get the forks for.
    Here's a list of the mods needed for the CR85 Fork Swap:
    You will use your existing CRF150F front wheel with disc.
    *1996-2007 CR80/85 Forks with top and bottom triple clamps
    *1996-2007 CR80/85 Front Axle
    *1996-2007 CR80/85 Fork Guards
    *1996-2007 CR80/85 Front brake hose clamp that clamps to the lower right fork guard
    *1996-2007 CR80/85 Front fender/OR you can use the stock CRF150F Fender.
    *1996-2007 CR80/85 Front # plate/OR you can use the stock CRF150F Plate
    *You will have to send the CR80/85 lower triple clamp to Reger Engineering to have the stem pressed ($60)
    *Reger Engineering Brake Adapter
    *The left front fork leg will need to be helie coiled in order to accept the Reger Engineering Brake Adapter
    *Reger Engineering 3 piece front wheel spacers and center support
    *Longer Front Brake line off a larger bike. ..125/250
    *Heavier front fork Springs for your weight and possibly a revalve
    This modification is NOT cheap, but I'm satisfied with my setup. IF you do the 85 forks swap, you'll want a better shock for the rear to balance things out. A Works shock, or some have used the CR85 shock.
    REGER ENGINEERING - Dirtbike, Motorcross, MX, MotoX, Motorcycle parts and accessories - Santa Cruz, California
    speeddemon619's Avatar
    Mar 2008
    Northeast Ohio
    I have no idea about this swap so sorry for my ignorance possibly, is it possible to use the cr80/85 fron brake setup and complete wheel?
    is out of business
    Aug 2006
    Oakley, California
    Quote Originally Posted by speeddemon619
    Yes, you can.
    Only down fall when using the CR80/85 front wheel/brake system....the CR braking system is a single piston caliper, where the CRF150F is a dual piston caliper.
    Better stopping power when using the stock CRF150F brakes.
    Some riders say they don't feel a difference when using the smaller CR80/85 brakes, and some say their horrible. Riders preference
    Wandell's Avatar
    Jul 2007
    Cairo, Georgia
    So, it's easier to just bolt on the complete CR85 front end but the brakes are not as good?
    schofell84's Avatar
    Feb 2007
    Ogdensburg, NY
    why in the world wouldn't you just get the stock forks resprung/revalved?
    is out of business
    Aug 2006
    Oakley, California
    Quote Originally Posted by Wandell
    Easier, Yes..
    You would only need to have the stem pressed ($60) and purchase Reger's steering stop ($25).
    But it could cost you more depending on how much you can pick up a complete front end with wheel, forks, brakes, etc.. Or could cost less..
    rotax10's Avatar
    Oct 2008
    MOSES LAKE, WA
    I have an entire cr 85 front end for sale, BBR springs, revalved by devol, stock triples, brakes, black pro wheel, fresh knobbie. pm if your intrested. the brakes work fine. I also have the matching rear wheel. they are the big wheels. 19-16
    $500. front end-$200 rear wheel
cr85 forks
cr85 forks for sale
cr85 forks on crf150f
cr85 front forks
cr85 front forks for sale
crf150f rear shock for sale
crf150f shock
crf150f with cr85 forks
forks for cr 150
swill the 250r rear spring fit the crf 150f?
will a crf150f rear wheel fit a cr80
would 150r forks fit a 150f
