need some info on an xr70
This is a discussion on need some info on an xr70 within the Bigger Minis Forum forums, part of the General Talk category; 1. what size are the stock pilot and main jets? 2. how much motor oil do u put in the case? 3. where can i ...
Results 1 to 3 of 3
    macattack's Avatar
    Feb 2005
    3. where can i order jets for my xr70 online?
    4. if i remove the choke assembly, what should i use to plug the hole?
    2003 CR250
    2002 XR70 (soon to be CRF50!)
    rjpracing's Avatar
    Dec 2003
    sunnyvale ca usa,five dock nsw ,australia
    you sould get a trailbike's 20mm carb with manifold for stock head and it comes with jets, it will work with any combo just have to spend the time to jet it right! so don't remove the choke is more of a pain than its worth in power!
    There is no rite or wrong just what works!
    builttospill6262's Avatar
    Nov 2005
    albunny,ny
    if you do though then use a eraser head
where to buy xr 70 jets
xr70 bigger jet
