xr 80 head testing
This is a discussion on xr 80 head testing within the Bigger Minis Forum forums, part of the General Talk category; sorry...
Results 1 to 20 of 20
    storminnorman07's Avatar
    Nov 2005
    new castle, pa
    xr 80 head testing
    sorry
    gman's Avatar
    Apr 2008
    Pittsfield, Massachusetts
    Re: xr 80 head testing
    I've been wondering about roller bearing conversion options... I Considered purchasing a Takegawa stage 3 and line boring the head and holder. IMO +$200 cam really isn't a attractive up grade for the stock head.
    Looks like the inexpensive Lifan "short" performance cam could be an alliterative option?? You would happen to have one laying around for a comparison pic/dimensions?
    Nov 2005
    new castle, pa
    sorry
    theraymondguy's Avatar
    May 2010
    Niagara, ON
    xr100 xr 100 head journals - eBay (item 230570623441 end time Feb-04-11 1437 PST)
    Not in line with your lifan direction, but there's lots of folks in need of a service like this...
    Nov 2005
    new castle, pa
    sorry
    is Ride this
    geezer's Avatar
    Dec 2009
    Blackwood N.J.
    Really nice looking work! As usual.
  7. #7
    Banned
    firepower354's Avatar
    Oct 2006
    Flint MI
    Quote Originally Posted by theraymondguy
    We used to make 1/2 spacers like that to run smaller mains in BB-Olds race engines, at Batten. Worked fine.
    I dare you to JB Weld a grooved-up one and see how long it lives
    Cam far end can be turned down like the DrATV 6v50/70 cam, but the drive end will need more work.
    Contact me offline, Chad. Project for you
  8. #8
    May 2010
    Niagara, ON
    Quote Originally Posted by storminnorman07
    thats why i decided to play with this old head i have. seems like alot of guys put a good amount of time and money in their stock head and in the end the journals go to ****. i was orignally going to source bearings that would press onto the stock xr cam and line bore for the bearing that works. that way for the guys that have already ponied up for a hot cam or web cam it would be a option to restore a junk journaled head. but g mans thought w/ the lifan short might be a good opiton also.
    http://ep.yimg.com/ca/I/dratv_2140_58590244
    Yes sir, continue on.
  9. #9
    2bamp's Avatar
    Dec 2006
    Quote Originally Posted by firepower354
    I've been amazed at what JB Weld can do. Have you ever seen this done?
  10. #10
    Banned
    Oct 2006
    Flint MI
    Quote Originally Posted by 2bamp
    Nope, but I'm gonna try. LOTS of XR junk heads around here...lol
  11. #11
    gman's Avatar
    Apr 2008
    A few months ago I started playing around some 3D cad models of a retro fit cam holder. Similar idea to the first gen XR 75's- But a two piece design based on the late model stock XR's holder. However, it would require to mill .250-315" of the holders foot print... I might send a STL file off to a 3D printing service for a prototype. I also have a few cooked heads, including a Take SH.
    Needs a little refining- its close tho
  12. #12
    Nov 2005
    new castle, pa
    sorry
  13. #13
    gman's Avatar
    Apr 2008
    Yup, I agree! It's more or less exploring a brain storm... Unsure of the cost to manufacture, I haven't tried to pursue the project. Maybe someone with a T&M CNC shop will chime in. However, really only the lower half is needed- if the precision is there...
    I was hot on that Lifan cam idea a while back- Unfortunately, I have a hard time piss'n $50 now a days..
    Did you come across a cam in your stock?
  14. #14
    Nov 2005
    new castle, pa
    sorry
  15. #15
    Nov 2005
    new castle, pa
    sorry
  16. #16
    gman's Avatar
    Apr 2008
    I would like to say lean towards the split bearing for the stock cam. Only cuz what you stated above about performance cams options for the 80/100's. (Unfortunately, If the heads cooked so is the cam) But before ya know it- cam repair labor + Bearings + performance/cam replacement= $$$...
    What I liked about the Lifan cam- was (a little) added performance (as was as the needed replacement for most users) and bearings at $35 from DRatv. I'm unaware of other performance cams on the market for Lifan engine line- specs and cost. Re drilling a 100 cam shouldn't a big issue for us 100 guys cost wise
    $$ most always drive a product and service...
    It will be intresting to hear what others have to say- forsure
    Can't wait to see the project underway wichever path you choose
  17. #17
    May 2010
    Niagara, ON
    Both!
    Bearing set for the guy who just wants to lump it together; Lifan short cam & sprocket for the guy who's going to tear down & rebuild. Around here a new head w valves goes for $350 from Honda. Hell of a way to spend money on an engine full of metal debris.
  18. #18
    Nov 2005
    new castle, pa
    sorry
  19. #19
    Nov 2005
    new castle, pa
    sorry
  20. #20
    gman's Avatar
    Apr 2008
    yeah thats why i'm hoping to get some replies from guys see which option most guys would ike more. both are def doable. i just picked up the 73-76 style cam block that is def a doable setup to place down on the new style head but thats alot of machine work so i know thats a no go for a option.
    Ya, It's to bad the stud spacing is offset lil, and there really isn't large lump available for the gen 1 XR 75. Was looking a the old fifty performance cams for a retro fit in the 75's holder... Man- I/we all must have some freak XR upright sickness- your mutant motor is a air born infection!!! Thanks alot! lol
cleaning a xr80 head?
webcams xr80 cam
xr 80 cam race specs
xr100 bearing cam conversion
xr100 cam bearings
xr100 cam journal
xr100 head cam journal repair
xr100 jbweld head
xr80 head on xr100
xr80 journal repair
xr80 roller bearing cam
xr80 xr100 head
