Mutant Motor Xr/klx
This is a discussion on Mutant Motor Xr/klx within the Bigger Minis Forum forums, part of the General Talk category; jealous! looks awesome!...
Page 2 of 14 FirstFirst 1 2 3 4 12 ... LastLast
Results 21 to 40 of 272
  1. #21
    connorpb7's Avatar
    May 2009
    Atlanta
  2. #22
    50rider340's Avatar
    Mar 2004
    CT
    Now thats some pretty hardware you got.
  3. #23
    storminnorman07's Avatar
    Nov 2005
    new castle, pa
    havent posted anything for a while figured i'd give a small update. got some motovation today to get back on wrapping things up on my build. before i started i sat down made myself a list of things that needed to be completed. i started to tackling the rest of the motor work when i ran into a uh-oh. i used xr 80 cases w/ the xr 100 crank. well when i was dimensioning both when i first started i never thought to check spec on timing chain crank gear. prolly thinking different size, if you where your right. the xr 80 timing chain crank gear is rougly .090th smaller than the 100. being i set everything up for 80 specs this kinda throws wrenchs in my plan. thought about boring the 80 gear to work w/ the 100 crank by the time i get it to size it only leaves me with .020-.030th material on all sides so i vetoed that idea in a hurry. so now i'm left with crank grinding to get the crank to the size i need or figuring out another gear selection and timing chain length. i decided on going different gears and chain length in hopes it works out that way in the furture if i need a new crank i wouldn't have to do extra work to the crank to run this setup. minus that snag i have just about everything else done. all thats left for the motor is fiigure time chain out, tap in the cases to run a line to the head, clay and check valve to piston clearance notch if needed, drill two holes and tap for the startor plate, then i can do a final clean and assemble.
    prep work on the frame is going about as fast a a herd of turtles through peanut butter. i did start doing some prep work tonight didn't take long before i got bored with it though.
    fins milled for exhaust clearance
    side by side comparison of the polish work on motor mounts still needs a final buff but you get the picture
  4. #24
    Daniel_1988's Avatar
    Oct 2010
    Waco, TX
    I've had that one stump me. Installed a xr80 head on a 100 and couldn't figure out why it wouldn't run. I was assuming they used the same cam gear. I was wrong haha, switched gears and it started right up.
  5. #25
    Nov 2005
    new castle, pa
    Quote Originally Posted by Daniel_1988 View Post
    i knew they where different gears. 100 has the 30/15 setup and 80 has 28/14. the shaft on the crank where the gear is pressed onto thats different od between the two.
  6. #26
    Nov 2005
    new castle, pa
    after all nice days we been having i decided it was time to get back after the mutant. would of got the motor completed tonight but ran into a uh oh. i was cutting notches in the piston went off the specs of the uncut piston and perfed it oh well dumb mistake on my part. should have a new piston by wednesday if all goes right. then i can cut it down assemble it. then all is needed is i need to do a custom line to feed oil to the head and finish the backing plate. since i ran into the snag with the piston i start dry fitting everything on the frame to weld some tabs for the oil cooler and started prep work to make the cooler. with any luck it should be ready to go to p/c by end of week. fingers crossed.
  7. #27
    507 brett's Avatar
    Jan 2007
    mt. pleasant, NC
    lets say that i wanted one of these motors, how much would you charge to build another one just like this one?
    (not a serious question lol)
    such a sick build, cant wait for it to be done
  8. #28
    Nov 2005
    new castle, pa
    Quote Originally Posted by 507 brett View Post
    trying to get my thread booted/locked....lol if i were allowed to state things like that it prolly would surprize some guys. dont get me wrong its expensive but compairing it to takie's crate motors its in the ball game and the mutant has ceramic bearings throughout, ti valves, custom seats, custom springs, custom guides etc..
    i cant wait for it to be done also i'm ready to see if its going to go or blow
  9. #29
    507 brett's Avatar
    Jan 2007
    mt. pleasant, NC
    i figured with all the work you put into it....
    but yea, that's why i said it wasnt a serious question haha id hate to getcha in trouble with the PM police.
    and i think that a 'mutant' motor like this would be the ticket over a taky regardless which is best bang for the buck.
  10. #30
    j440's Avatar
    Oct 2007
    CT
    i hope this thread doesnt get closed or deleted.. i really enjoy following this build lol
  11. #31
    mx rider's Avatar
    Apr 2009
    NC
    wow i wish i had the equipment to build something like this.
  12. #32
    Nov 2005
    new castle, pa
    haha yea i have got a thread or two locked or deleted from not carefully wording my opinion. i think the mutant is the ticket also at least thats what i'm banking on lol. i have riden all of the takie staged heads and the kitaco se head and compaired to my 50 motors they are all tail draggers. however the +r head i just recently did for my buddy did show some good potential.
    worked on it some more tonight got the piston done so now its ready to be ringed and dropped on the bottom for the final time. i will have to take the clutch cover off and cut on it there is a tab thats not on the stock cover and seeing how i used the stock cover for mocking my exhaust up and welding it and made clearances pretty tight to the clutch cover that tab will need to go in order for my exhaust to line back up. after finishing up the piston i started on my oil cooler and almost have that complete just need to figure how i'm going to mount it and weld some tabs on it and its done. once i get the cooler, tab cut off the clutch cover, and fab two braces for the supports on the bottom of the shrouds things can go out to p/c. im shooting for friday and so far its looking good.
  13. #33
    Nov 2005
    new castle, pa
    Quote Originally Posted by j440 View Post
    i'm glad to hear there are some guys on here that still enjoy builds like this one.
  14. #34
    twosmoke30's Avatar
    May 2009
    Quote Originally Posted by storminnorman07 View Post
    this is one of the few/if not the last "do it yourself" thigns you can do now in the pitbike world, this is such a cool build, i wonder if a mutant like that would fit in a xr75 chassis?...
  15. #35
    AngryDirtbikers17's Avatar
    Aug 2008
    NH
    i agree
    chad what kind of exhaust is that?
  16. #36
    Nov 2005
    new castle, pa
    Id say itwould fit intake would be the bear to get to work.
  17. #37
    Nov 2005
    new castle, pa
    Its a jardine r5
  18. #38
    Nov 2005
    new castle, pa
    well guys the mutant motor is virtually done i didnt get no where near as much done tonight as i would of liked to. a local roundy poundy racer stripped a head stud on his block tried heli coiling it wadded it up and did this like 3 times. needless to say i somehow got dragged into machining a slug for him to go race this weekend. so my high hopes of having the frame ready to go to powder by friday is dwindling. heres a few pics of the cooler shortly after doing some touch up welding, the crf 50 stage 3 tokyo mods ignition i modded to work on the xr bottom mag cover shot and i didnt think to take a video while cutting the piston for the mutant had to do a couple for a guy so i shot a lil clip of that to verfie i'm doing my own work.
    not bad for being a used junk yard ford explorer power steering cooler and alum. stock
    [youtube]http://www.youtube.com/watch?v=GjVBQrKkGwA[/yotube]
  19. #39
    is looking for a pit bike let me
    kno if you got one your trying
    to get rid of!!!!
    love2wheels's Avatar
    May 2011
    Sumter, South Carolina
    cant wait to see this thing finished love seeing the updates!!!
  20. #40
    50rider340's Avatar
    Mar 2004
    CT
    NICE Chad you posted up your set-up. Pictures equals knowledge
cr com motor de xr
cr motor xr
cr xr motor
klx siki?
motor xr
motorxr
mutant motors
planet minis mutant
www motor xr.com
www.motor xr.com
www.motorxr.com
xr motor in cr frame
