Ttr125l playbike build - Page 7
This is a discussion on Ttr125l playbike build within the Bigger Minis Forum forums, part of the General Talk category; Well the 150r carb is a no go. It's too tall and too wide to fit in the frame and have even a half way ...
Page 7 of 7 FirstFirst ... 567
Results 91 to 105 of 105
Like Tree12Likes
Thread: Ttr125l playbike build
  1. #91
    greenducky55's Avatar
    Nov 2009
    Fresno, CA
    Well the 150r carb is a no go. It's too tall and too wide to fit in the frame and have even a half way decent airflow path. So it's been tentatively sold (as long as I receive payment) and I've started ordering up the next set up. I am usually a guy who goes with the simplicity rule but I am already way passed that.
    Future fueling/ignition plan.
    Microsquirt EFI/Ignition
    Coil on plug
    34mm throttle body
    160-180cc injector
    Yamaha YBR 125 Flywheel
    External fuel pump/regulator
    And a whole ton of luck. In the mean time while all of that is on order. im fixing up a few things on my cb750 to kill time. The new intake valve should be here in a week or so. And I'll finish up the bottom end.
  2. #92
    is 10 year member still has no
    status
    spiz5's Avatar
    Feb 2004
    Frankfort Il
    I was gonna suggest looking at the Yoshimura TM series carbs, but you blew right on by that idea.
  3. #93
    Nov 2009
    Fresno, CA
    Haha yeah I was debating on it but I've been wanting to do a go conversion on something for years
    Nov 2009
    Fresno, CA
    Well still waiting on quite a few key parts but I've started mocking up and building my wiring diagram. Don't want to splice the harness until I know 100% I'm happy with placement. But here's a quick cardboard mock up. Also oil Cooler mocked up.
  6. #95
    NHrider's Avatar
    May 2006
    WOW...that's all I got. haha
  7. #96
    rsjkwells's Avatar
    Jun 2014
    Carmel Valley,Ca
    I'm more of a HOLY CRAP!!!! kind of guy!!! I can't wait to see this thing go!!!! You've got some serious confidence to go that route on the EFI!! Although I totally understand your reasoning. I wouldn't know where to start, what maps to use ..etc!!!! Good job!!! I'm seriously inspired!! WAY TO GO!!!!
    -Robbrt
  8. #97
    Nov 2009
    Fresno, CA
    Well wiring should be sorted as far as where to connect what once I'm ready. Got the electronics box half way done. Think I've sorted out where I want to put everything. Made the new ports in the fuel tank had to get a little red neck on it but it doesn't leak fuel currently.
    Used 1/8" aluminum used the oem petcock mounts. Tapped the aluminum for 1/4" fitting which convert to 6an. Then for the return port drilled tapped and helicoiled the tank for 6mm bolts. Then also drilled and tapped the aluminum for 1/4" npt. Then covered the whole backside of both plates with yamabond which is fuel safe. If all else fails I have a few back up plans. Have some base maps set up which should get me all up and running.
    StorminNorman did up the new flywheel as well. Click image for larger version.
  9. #98
    Nov 2009
    Fresno, CA
    Well some mild updates. The electronics box is almost ready to be replicated in carbon fiber. Still need to figure out a few mounting points and finish up the rough wiring. Then it will be off for some fabrication work for the intake manifold and getting some brackets welded. Need to order my iac motor controller for the microsquirt. Might be slow going due to money constraints right now with some medical bills. But should at least have the wiring done soon.
  10. #99
    Wandell's Avatar
    Jul 2007
    Cairo, Georgia
    Keep the updates coming man!
  11. #100
    Msf0002's Avatar
    Aug 2016
    I just bought a ttr125 this week and I have been spending countless hours researching engine upgrades. This is like the Holy grail. I hope you get it running soon, I can't wait to see a vide!
    Wandell likes this.
  12. #101
    Nov 2009
    Fresno, CA
    who is ready for some updates!!!! I'll upload some pics this weekend hopefully. finally received the last of my electronics so I can start working on wiring the microsquirt unit. and I'm hoping to start my fiberglass work on the electronics box next week. then it's off to the fabrication shop for a custom intake manifold for the throttle body.
    Wandell likes this.
  13. #102
    Wandell's Avatar
    Jul 2007
    Cairo, Georgia
    Looking forward to it!
  14. #103
    Nov 2009
    Fresno, CA
    Oh well i had uploaded on the facebook page but guess i should post it on here. ive now got the microsquirt 99% wired just need to make my intake manifold and weld up the O2 sensor bung. im also waiting on my BBR air filter and then i need to build my fuel tank. hopefully i will be all up and running by end of January.
    I am now using a KTM 450sxf fuel pump as its an in tank model and all self contained. i need to save some space.
ID:	193905Click image for larger version.
ID:	193913Click image for larger version.
    Wandell likes this.
  15. #104
    bicycleweed's Avatar
    Dec 2015
    Amazing build!
  16. #105
    Nov 2009
    Fresno, CA
    Alright so I ordered a finalized can sprocket it came in and I specified the wrong size bolt holes. So need to order up another set but looks like I can finally supply sprockets here shortly. Other news I received my bbr high flow filter I can't believe I waited so long to order one. Thing is freaking huge! Finalized my wiring the other day. Now waiting for a buddy of mine to have free time to weld up my fuel tank and intake manifold and we'll be set!
    Wandell likes this.
  1. TTR125L carb-$35
    By Chucky in forum KLX110/Midsize Parts for Sale
    Last Post: 04-07-2012, 07:20 AM
  2. Ttr125L Problems
    By sliding68 in forum Bigger Minis Forum
    Last Post: 01-07-2012, 05:05 AM
  3. 2002 Ttr125L $750
    By Dr.Wreck in forum Complete Bikes For Sale - All makes and models
    Last Post: 06-06-2011, 11:58 PM
  4. full mod ttr125l
    By mr.skywalker in forum Complete Bikes For Sale - All makes and models
    Last Post: 12-23-2010, 03:07 PM
  5. moto234 crf50 playbike build
    By moto234 in forum CRF50
    Last Post: 03-04-2009, 12:36 PM
does the flywheel have to be in a certain spot when replaced on 07 yamaha ttr 125
graphic kits ttr125l
problems fitting 180cc kit to 125 gladiator
raptor 125 big valve head
senge graphics
ttr 125l
ttr for playbike
ttr125l
ttr125l black rims
yamaha ttr 125 4 valve head
yamaha ttr125l build
zuma 125 head on raptor 125
