My TTR125/YZ80 conversion
This is a discussion on My TTR125/YZ80 conversion within the Bigger Minis Forum forums, part of the General Talk category; I always wanted to build one as a kid, but even better, now I get to build one as an adult. I will be posted ...
Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Like Tree3Likes
Thread: My TTR125/YZ80 conversion
    bsiyota's Avatar
    Dec 2012
    I will be posted pics and a detailed step by step when I do the swingarm/shock conversion.
    Just did the front end today.
    Had to trim a couple inches off the YZ fender to clear the exhaust.
    Took just under two hours to do the swap.
    Started tearing apart the rear shock to put new seals in. Got hung up on getting the cap off. Gonna have to wait till after Xmas to get access to a tool to get it off.
    crazybeetch4 likes this.
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    WoW seems like a Hugh improvement with the YZ85 Forks upfront !
    T Bolt USA - Let's go riding!
    bsiyota's Avatar
    Dec 2012
    ungwaha's Avatar
    Jan 2013
    What was involved with changing the swing arm? Just weld on some new shock linkage mounts? Did you have to grind a spot for the shock piggy back?
    Sorry about the noob questions but i just got a TTR 125 and looking to do the conversion since I am big fat guy using a little bike to improve my riding.
    Will the TTR motor fit in the YZ chassis?
    andy#802's Avatar
    Jul 2012
    Australia, Earth
    Did the yz triple clamp fit straight onto the ttr?
    Quote Originally Posted by bsiyota View Post
    Did the yz clamp fit on the ttr chassis without fabrication?
    USERNAME's Avatar
    Jul 2006
    Monee, IL.
    Nice bike good job on the work. Those graphics on the yz remind me of mine i had the same bike and graphics it was my first dirtbike! lol
    bsiyota's Avatar
    Dec 2012
    bsiyota's Avatar
    Dec 2012
    The YZ clamps fit without any fab work. You use the YZ lower bearing and the TTR upper bearing and you have to put a couple washers under the hex nut or else you run out of threads. The swap took me less than two hours
    andy#802 likes this.
  10. #9
    bsiyota's Avatar
    Dec 2012
    Quote Originally Posted by ungwaha View Post
    The swing arm needs spacers on either side because the YZ swing arm is slightly narrower. You have to notch out the frame for the piggyback as well as re drill the upper shock mount. If you run the piggyback on the right side you have to either run a pod air filter or make a new air boot to the air box. Or you can run the piggyback on the left side but you have to modify your exhaust. If I didn't have the bbr stainless exhaust I would have done that but I don't want to have to bend really thing tubing and tig weld the SS.
    Im moving the battery to the airbox and running a pod filter.
  11. #10
    bsiyota's Avatar
    Dec 2012
    Putting the TTR motor in the YZ frame is a much bigger project and requires tons of work but in the end would be a better bike. The YZ frames are much stronger.
  12. #11
    is 10 year member still has no
    status
    spiz5's Avatar
    Feb 2004
    Frankfort Il
    Awesome welds.
  13. #12
    bsiyota's Avatar
    Dec 2012
    Quote Originally Posted by spiz5 View Post
    Awesome welds.
    Thanks!
  14. #13
    bsiyota's Avatar
    Dec 2012
    Boom picked up a filter today. Actually fits in there really well. The boot has a slight angle too it. Mounted it so the filter is turning inward. The filter has a big spring inside it so it keeps it's shape, but the filter wedges itself up against the piggyback l and makes for a nice snug and out if the way fit. Pumped. It also seems like it runs perfect with a 20 pilot and a 110 main. But that's just revving it up in the driveway.
  15. #14
    bsiyota's Avatar
    Dec 2012
    First test ride. Everything worked flawlessly.
  16. #15
    status
    spiz5's Avatar
    Feb 2004
    Frankfort Il
    Shorts on, sun shining, rolling hills in the baxkground, I hate you.
    (its 15 degrees here in Chicago.)
  1. Yz80 swap?
    By XR 50 in forum 2 Stroke Pitbikes
    Last Post: 04-23-2012, 09:57 PM
  2. any yz80/85 seats same as '03 ttr125 ?
    By iomfan in forum Bigger Minis Forum
    Last Post: 02-10-2011, 07:50 AM
  3. Wtb yz80
    By Samizx7 in forum Bikes and Parts Wanted - All Makes
    Last Post: 10-21-2009, 10:48 PM
  4. 70 drum to 50 wheel conversion? conversion
    By BlackBeard in forum CRF50
    Last Post: 06-08-2008, 03:48 AM
  5. My friends TTR125 with YZ80 forks
    By CRF#319 in forum CRF50
    Last Post: 08-05-2006, 05:17 PM
ttr 125 convert in yz 80 frame
ttr 125 engine swap
ttr 125 full yz suspension
ttr 125 yz 80 forks
ttr yz swap
ttr yz upper mount re drill?
ttr125 conversion
ttr125 yz80 conversion
yamaha yz80 frame conversion
yz80 forks
yz80 forks on ttr 125
yz85 swing arm in a ttr 125
